586,069 active members*
3,592 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > looking for 10m servo wire color identify
Results 1 to 11 of 11
    Oct 2009
    230
    not sure how to word that
    i have a mill i am retrofitting and cant recall which wire color does what
    there was a great picture in google but for the life of me i cant find it again!
    there is 4 power wires and a yellow ground
    on the machine it had the 2 pairs of power wires joined at the drive
    shizuoka an-s knee mill=kflop/kanalog running nema 34 dc brushed servos
    cincinnati sabre 750=kflop/kanalog building now with ac brushless servos
    24221
    Re: looking for 10m servo wire color identify
    Is that " 2 pairs of power wires joined at the drive" mean 2 pairs connected together?
    Implying there is just one pair of supply conductors needed?
    What is the motor technology?
    DC? BLDC? etc.
    Albert E.
    Oct 2009
    230
    4 power wires out of the brushed servo. 1 ground wire
    i followed them to the board and at the terminal strip they were paired with lugs.
    so i am assuming they have a basic + and - power requirement
    Oct 2009
    230
    Aug 2019
    145
    There is no standard color code for that cable. You will need to ring out the wires or open the connector at the motor end.
    Pins C/D is A1 and pins F/G is A2. Pin P is ground.
    Now A1 and A2 may need to be swapped as pairs to get rotation direction right.
    Oct 2009
    230
    excellent
    thanks i will give it a go.....
    Oct 2009
    230
    additionally i found this in the manual i have but it is not too clear to me
    24221
    You can trace/identify continuity of each A1/A2 pairs from the MS3108 connector end.
    Albert E.
    Oct 2009
    230
    A1 and A2, are these both just power wires to drive the servo or is one a field winding or some other magic?
    24221
    These motors were PM field. Hence per label EXCIT(ation) - PERM Magnet.
    Albert E.
    Oct 2009
    230
    thanks
  1. Stepper Motor Wire Color Configuration
    By Cornelius3D in forum Stepper Motors / Drives
    Last Post: 01-20-2013, 06:43 PM
  2. Are the wire color of stepper motors standardized?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 01-22-2011, 11:30 PM
  3. motor wire color in cnc conversion
    By MPaulHolmes in forum Benchtop Machines
    Last Post: 08-10-2009, 12:19 AM
  4. Wire color code HP laserjet II steppers
    By rustranch in forum Stepper Motors / Drives
    Last Post: 02-14-2005, 05:40 AM
  5. Wire Color
    By HillBilly in forum CNC Machine Related Electronics
    Last Post: 07-26-2004, 06:04 PM
