586,065 active members*
4,842 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > while/endwhile constructs do longer work
Results 1 to 13 of 13
    Aug 2021
    4
    I have over 100 hand coded gcode files that ran perfectly on a Mk1 controller with 2.10.1412.1501 on WindowsNT. I recently updated to 2.10.1807.2601. After the update all my existing files that had while/endwhile constructs stopped execution (actual and simulated) after the first encountered endwhile statement. All existing files that did not have while/endwhile constructs continued to run perfectly after the update.
    Any suggestions?
    Is a download of 2.10.1412.1501 available to revert my update?
    Jun 2015
    4154
    Re: while/endwhile constructs do longer work
    hy what about replacing all your loops with linear code ? maybe i can help you
    Mar 2017
    1312
    Send me this g-code and I'll check what is wrong.
    Aug 2021
    4
    Here's an example of the g-code. Before the software update to 2.10.1807.2601 this gcode drew two concentric five point stars (it's a test pattern). After the update it only draws the smaller star and stops execution after line 30. I've attached a screen shot. It shows only the single star.
    Thanks. Your help is greatly appreciated!
    (Star test pattern - little first)
    (For 450nm laser)
    (Laser uses output 1)
    (Use M3 to turn laser on)
    (Use M5 to turn laser off)
    (X, Y = 0 is the center of the star)
    (Z = 0 is laser focal point)
    G17 G21 G40 G80 G90
    G92.1
    F[1000]
    #1 = [15] (little R)
    #2 = [#1 * [1.5 - [sqrt[5] / 2]]]
    #3 = [0] (rotation angle)
    G0 x[0] y[#1] (starting point)
    M7 (turn mist/air on)
    M3 (turn laser on)
    o100 while [#3 LE 288]
    G1 x[#2 * sin[36 + #3]] y[#2 * cos[36 + #3]]
    G1 x[#1 * sin[72 + #3]] y[#1 * cos[72 + #3]]
    #3 = [#3 + 72]
    o100 endwhile
    M5 (turn laser off)
    #1 = [25] (big R)
    G0 x[0] y[#1]
    M3 (turn laser on)
    o200 while [#3 LE 288]
    #3 = [#3 + 72]
    o200 endwhile
    M5 (turn laser off)
    M9 (turn mist/air off)
    M2
    Mar 2017
    1312
    I can confirm this is a bug.
    Aug 2021
    4
    Thanks. Do you know where I can find a download of 2.10.1412.1501? That was the version I was using before the update that worked.
    I checked the planet-cnc.com web site but there didn't appear to be any place to download older versions.
    Mar 2017
    1312
    Contact our support
    Aug 2021
    4
    Thanks! I'll contact support now.
    May 2014
    11
    Is there any fix for this bug?
    Mar 2017
    1312
    Both stars are visible and g-code runs as it should.
    May 2014
    11
    Hello,
    yesterday I was playing with nested while and it seems that only one cycle of the outside loop is executed.
    I've also tried to use a simple counter in the outside loop instead of the derided behaviour to exlude any programming error
    G21G54G90G17
    #1=12 (diameter)
    #2=30 (x side)
    #3=22 (y side)
    #4=0.4 (stepover)
    #5=0 (z)
    #9=300 (vertical feedrate)
    #<_DEPTH>=-10
    #<_ZSTEP>=-1
    #<_HFEED>=2000
    #<_STEPOV>=[#1*#4]
    #<_RADIUS>=[#<_STEPOV>/2]
    #<_ENDY>=[#3+#1]
    (start outside)
    #10=[0 - #1*2]
    #11=[0 - #1*[1-#4]]
    G0 X#10 Y#11
    G0Z0.1
    #10=[#2+#1]
    #<_CURRZ>=#<_ZSTEP>
    (cycle Z)
    #100=0
    (O100 WHILE [#<_CURRZ> GT #<_DEPTH>])
    O100 WHILE [#100 LT 10]
    (G1 Z#<_CURRZ> F#9)
    G1 Z#100 F#9
    (cycle XY)
    O110 WHILE [#11 LT #<_ENDY>]
    G1 X#10 F#<_HFEED>
    #11=[#11+#<_STEPOV>]
    G3 Y#11 R#<_RADIUS>
    G1 X[0-#1]
    G2 Y#11 R#<_RADIUS>
    O110 ENDWHILE
    #<_CURRZ>=[#<_CURRZ> + #<_ZSTEP>]
    #100=[#100+1]
    O100 ENDWHILE
    G0Z10
    G28
    P.S. I have version 2.10.1807.2601 like the user at the beginning of the thread
    Mar 2017
    1312
    CNC USB software is obsolete for 10 years and not supported any more.
    You should update to latest TNG software.
    May 2014
    11
    Problem is: I have a MK2/4 board. I suppose it is not supported by TNG. Am I wrong?
    Unluckly, I bought the MK2/4 board many years ago but I have completed my cnc project only this year!
  1. Z levels no longer work after update
    By justCNCit in forum MadCAM
    Last Post: 07-31-2017, 04:34 AM
  2. CNC Router Work Station
    By StgIIIWi in forum For Sale Only
    Last Post: 06-09-2015, 07:06 PM
  3. O codes and WHILE/ENDWHILE loops
    By greybeard in forum G-Code Programing
    Last Post: 04-05-2010, 09:53 AM
  4. WHILE, ENDWHILE, Case, switch
    By haecker1 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-30-2008, 08:35 AM
  5. No longer Looking for work around Arlington, TX
    By Rick57 in forum Employment Opportunity
    Last Post: 04-22-2006, 04:23 PM
