586,036 active members*
4,317 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > use Enable terminals with a toggle switch as a stand by mode
    Jun 2020
    I am using a nema 34 stepper to drive the lead screw on my HF 9 x 20 lathe. It is used strictly as a variable speed motor. i need to know how to wire the enable terminals with a toggle switch to use them to put the driver in basically a stand by mode. Also i will use the standard gears to cut threads When i am using the gears will the stepper generate electricity and damage the driver? Dan
    Dec 2013
    5717
    Re: use Enable terminals with a toggle switch as a stand by mode
    Quote Originally Posted by danbob5 View Post
    That should work OK.
    Yes, the stepper will become a generator and most likely will damage your stepper drive. I would put a plug on the motor cable so it is easy to disconnect when using the geared system. Make sure the power supply to the stepper drive is off when connecting/disconnecting the motor cable.
    Jim Dawson
    Sandy, Oregon, USA
  1. Wiring up an Illuminated toggle switch
    By ecope in forum Maintenance DIY Discussion
    Last Post: 06-12-2021, 12:28 PM
  2. Fanuc 6M write-enable toggle switch
    By MikeREvans in forum Fanuc
    Last Post: 04-08-2016, 03:59 PM
  3. Reversing an electric drill using a toggle switch
    By kazuo in forum CNC Machine Related Electronics
    Last Post: 12-29-2009, 11:48 PM
  4. Jog Mode Toggle
    By dynamotive in forum Mach Software (ArtSoft software)
    Last Post: 09-30-2009, 03:04 AM
  5. Q: Mach3 Wiring / Toggle Switch
    By Deviant in forum Gecko Drives
    Last Post: 02-11-2009, 04:21 AM
