586,117 active members*
3,615 visitors online*
    Mar 2011
    26
    Parameters affecting M00 and M02
    Hi you all!
    There are these two lathes which execute the code M02 differently; one stops the program and unlocks the door, while the other stops the program without unlocking the door. And then there's this mill which when executing M00 stops the program but won't allow the door to be (manually) unlocked without changing to JOG-mode (when on a lathe this is allowed without having to leave AUTO-mode).
    So I was wondering if this behaviour is set by some parameters and if so which one? I'd like M02 to stop the program and unlock the door (thus forcing you to open and close the door before continuing the program) and M00 to stop the program and allow you to unlock (and open) the door without leaving AUTO-mode.
    Thanks.
    Apr 2009
    1379
    Re: Parameters affecting M00 and M02
    Likely this is controlled by the ladder (PMC) and cannot be easily changed.
    Jul 2017
    50
    Our Doosans have different behaviors like that can be changed from the Keep Relays.
    I'd check the documentation for the machines.
    Mar 2011
    26
    I see, makes sense.
    Thank you for your replies memoryman and PNaedele.
    What are the odds that you can post both ladders?
  1. What is the difference between M30 and M02
    By sinha_nsit in forum Fanuc
    Last Post: 11-27-2021, 09:19 PM
  2. Custom M Code without M30 or M02 ?
    By yaji63 in forum Fanuc
    Last Post: 12-07-2016, 02:57 PM
  3. M30 and M02 functions availability
    By pmanoj in forum Fanuc
    Last Post: 10-19-2016, 06:32 PM
  4. Help me!! m30 and m02 restart machine
    By bigodinos in forum Fanuc
    Last Post: 11-09-2014, 11:41 AM
  5. Programming M02 / M30
    By TMILLS in forum Fadal
    Last Post: 11-30-2009, 09:08 PM
