586,103 active members*
3,855 visitors online*
    Dec 2009
    166
    Question Confused work offset
    Well after using using my home built machine for years, I now find my self a little confused
    My X axis home setup is Soft max =310 soft min = -310 Home off = 310
    So if I issue G53 X0 this places the X Axis dead center of its limits
    If I then enter G54 G92 X0 I would have assumed the G54 X offset would read either 0 or -310
    but it actually reads -358 there are no tool offsets and the tool number is set to 0.
    Maybe I have early dementia setting in.
    Can somebody shed some light on this thanks
    Nov 2012
    1267
    Re: Confused work offset
    Not sure how G92 works, but Mach3 manual suggests this command for setting work offsets:
    G10 L2 P1 X0 ;set G54 offset to X=0
    Dec 2009
    166
    Thanks for that it works great
    Nov 2012
    1267
    P. S. I tried the G92 command as well, and it worked as expected for me. Not sure why it didn't work for you. It's considered obsolete anyway, so I personally would avoid using G92 if possible.
  1. Replies: 9
    Last Post: 04-03-2024, 09:33 PM
  2. Replies: 11
    Last Post: 12-17-2016, 04:59 AM
  3. Replies: 1
    Last Post: 05-22-2016, 10:59 PM
  4. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 06-04-2012, 06:31 PM
  5. Tool offset with work offset
    Last Post: 05-28-2012, 09:48 PM
