586,058 active members*
3,492 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Setting up Z zero and fixed tool change electrically
    Sep 2003
    1469
    Mach 3, Smoothstepper, C25S BOB, Vectric 11
    Setting up for 2010 screen set
    Back home and continue setting up the inputs.
    I’m having some concerns about how I’m wiring the Material Auto Zero and the Fixed Plate for the Tool Change auto zero.
    My machine has continuity between the router bit and all the machine extrusions as well as the ball screw shafts. So the wiring layout shown below would not work. What do I need to do the work around this problem?
    Hager
    15362
    Re: Setting up Z zero and fixed tool change electrically
    Quote Originally Posted by Mr.Chips View Post
    Hager
    0-5v is a little wimpy for something like this 12v or 24v would be a better choice
    Have you checked with a meter the spindle body to see if you have the 0-5v it has to go through the Bearings, that is why a passive probing is best
    Something like this on eBay 254564463329
    Mactec54
    15362
    Forget what I said in the above post, except for the passive probe
    The 0-5v should make the circuit though the tool and touch plate, so you most likely only have some settings configuration that need to be changed
    Mactec54
    Sep 2003
    1469
    Thanks, what’s the difference between the one you showed (gold color) and this one I already have?
    15362
    You don't have to clip anything to the tool in the spindle, they have switch of some kind inside, (they are all different some better than others this was just for an example ) the center piston moves up / down to make the contact with the switch
    This can be mounted on the table and ready for every tool change, it can be used with every tool change automatically
    Mactec54
  1. Setting up manual tool change
    By Huskynut in forum CNC Machining Centers
    Last Post: 08-20-2015, 09:17 PM
  2. [noob] Setting Z after tool change
    By ToolChatter in forum BobCad-Cam
    Last Post: 12-08-2014, 10:57 PM
  3. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  4. Kit Mycent 3X tool change setting I 80 control
    By rick kroeze in forum Kitamura
    Last Post: 08-28-2012, 03:57 PM
  5. Setting the Z axis tool change height
    By TR MFG in forum Fadal
    Last Post: 11-07-2009, 04:22 AM
