586,121 active members*
3,758 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Flipped part and chamfers are offset on x axis
Results 1 to 20 of 24
    Aug 2009
    6
    Need a little help here. So I am flipping my part over to run side 2 which is nothing special just some facing and chamfering. I made a fixture for this part and I am using one of the holes as my 0 so that I would avoid this problem or so I thought. After I ran these parts the chamfers were visibly wrong. They were offset only in the X axis. So as a double check thinking I missed steps I broke out the indicator and swept the hole that I used as 0 again to see if it had moved or something and it had not. So as another check I moved the mill to the other two hole locations and swept those just to see if there was some error there and only found about .0015 error in location. I checked my fixture to see if it was still set square and it is within .001 in all directions. I reposted the program and reran one of them. Still no difference. I’m now not sure what it could be. The pictures are a little tough to see the difference but the left of the holes is a lighter chamfer than the right. The profile chamfer is heavier on the left end of the part and lighter on the right. Any help would be greatly appreciated.
    Jul 2018
    6341
    Re: Flipped part and chamfers are offset on x axis
    Hi SMW - Have you flipped parts before? When you do this the error is potentially twice the "clearance" in the fixture. Have to use chamfered pins or registers that are very tight to get correct registration both sides. Sorry no pics to look at. Peter
    Aug 2009
    6
    No I haven’t but I was wondering if that could be a potential issue. I’m using some of the cam screw type clamps and torquing the right one down first so it pushes the part to the left locking it against the fixture first. I do indicate each one since it’s a converted G0704 mill. Hasn’t really shown me that I need to but still just another double check.
    15362
    Quote Originally Posted by smw19822002 View Post
    If you interacted the hole X0Y0 and the chamfer is off with that hole, then it has to be in the program
    Mactec54
    Jan 2018
    1516
    Either that or, that is the backlash in the machine showing up.
    When you did both sides. Did you zero your WCS for X from the same table side (ie left side / corner)?.
    If you do so, one of the sides will be against the backlash of the machine. If you have say 0.002" backlash in the machine this would show up on ONE of the sides.
    When you flip it you should do for example..... on side 1- come in with cutter from bottom left corner.... flip it...... then come in from bottom right corner on side 2.
    This means your cutter will be coming in from the SAME position for both x+y on both sides. If you've done it right, the spindle will have past any mechanical baclash when you set your starting position on each side.
    If my dodgy explanation makes any sense to you.
    15362
    Quote Originally Posted by dazp1976 View Post
    If you indicate a hole ( X0Y0 ) the Backlash if any, would not be the cause of this much shift in cut
    He needs to check his drawing to see where the problem is
    Mactec54
    Aug 2009
    6
    I did I use the same side for both operations. The closest left on side 1 and the hole on the left on side 2. I did think also that the backlash might be getting me so I re-ran the same code with the backlash turned off and still have the same result.
    Aug 2009
    1573
    ...If, the Column (Z axis) of the machine is tilted a few degrees or just minutes (not perpendicular) to the X axis can cause what you have described. Tool length differences would magnify the offset error. Re Tram
    Aug 2009
    6
    I kind of checked that I ran my indicator across the top of the fixture just to see if it was not flat and it bounced around between .001ish across the 7 inches. It was better than I expected for sure.
    Aug 2009
    1573
    15362
    If tram is his problem he would see it in his part thickness and the edges would not be square to the machined top surface
    Mactec54
    Aug 2009
    1573
    ...yes everything would be out of whack. and when Fly cutting would be easy to spot if, you know what to look for.
    Dec 2013
    5717
    If you are locating on the hole with the indicator in it, it could be that the hole is not where you think it is. Might be offset very slightly. From the pictures, it looks like you need to shift the part to the right one or two thou relative to the tool.
    Jim Dawson
    Sandy, Oregon, USA
    Maybe I missed it, but are you indicating the hole center by using two opposite sides of the hole?
    EDIT: For the center in x
    15362
    Quote Originally Posted by StrawberryBoi View Post
    If you are indicating a hole you are doing the X and Y axis X0Y0 Point, this is the only way when using an indicator for this process
    Mactec54
    I just want to confirm they're not indicating only one side and taking the radius for the x-pos. It's unlikely they would do it this way, but just as you must ask oneself if the device is indeed plugged in and turned on, you must ask oneself even the most seemingly obvious things when troubleshooting.
    15362
    You could not set a hole center at all, with an indicator by just touching ( 1 ) side of the hole, not even with a probe, this would not work, you have to sweep the hole with a minimum of ( 3 ) Points, for an indicator, all ( 3 ) positions must be 0.0 on the indicator to give you a X0Y0 position. using a probe you normally do ( 4 ) points
    Mactec54
    Jan 2018
    1516
    Depending on the hole size, I kept a load of broken end mills of varying sizes.
    I use the shanks of these fitted into the spindle nose to line up to a drilled hole. Generally between sizes 3-8mm.
    Aug 2009
    1573
    ...use a nevusor nully Dial Indiccator...when Jig boring holes
    https://www.ebay.com/sch/i.html?_fro...apid&_osacat=0
  1. Part work offset
    By astral in forum Okuma
    Last Post: 03-13-2021, 10:16 PM
  2. Fillet and chamfers - 3 axis milling - CW4SW
    By itolond in forum CamWorks
    Last Post: 06-27-2018, 11:41 AM
  3. Replies: 2
    Last Post: 02-17-2013, 06:37 PM
  4. FLA-100. Flipped part wont line up! Software or mechanical?
    By Zeppelin1007 in forum DIY CNC Router Table Machines
    Last Post: 11-15-2012, 01:54 PM
  5. 5 axis chamfers and dovetails
    By gwb in forum Mastercam
    Last Post: 02-03-2012, 09:29 AM
