586,060 active members*
4,289 visitors online*
    Dec 2011
    15
    21i-t tool change position
    New to fanuc controllers. I have a Romi G30 with the Fanuc 21i-T.
    How do I change the turret position when it does a tool change?
    It wants to go to a spot it crashes tools into part and/or chuck.
    Re: 21i-t tool change position
    Parameter 1241. This is tied to G30 U0 (X0) and W0 (Z0). This value will be in MM so be careful if you are programming in inch. Input the value where you want the axes to go from MACHINE zero.
    Dec 2011
    15
    Quote Originally Posted by drdos View Post
    I will try it tomorrow.
    Thank you for info.
    Dec 2011
    15
    Tried 1240 and 1241
    Not it.
    It wants to do tool change at part x0 z0
    Dec 2011
    15
    I did find a work around, or for all I know it may be just the way to do it.
    In the Process you need to select the detail screen. The Approach values is where the tool will change at.
  1. Park & tool change position after tool probe.
    By Ozzybee57 in forum Mach Mill
    Last Post: 10-16-2016, 03:57 PM
  2. Replies: 2
    Last Post: 12-31-2014, 01:46 PM
  3. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  4. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  5. change Z position of the spindle in tool change
    By michael-p in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2011, 09:18 PM
