586,111 active members*
3,617 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Rhino ST6 CNC Lathe Restoration
    Aug 2003
    329
    Attachment 469004
    I recently bought a Rhino ST6 CNC Lathe from a Craigslist ad. The lathe is is OK shape but has a rusty cabinet. I did some research and it looks like these lathes were made in the 1990s for Schools.
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Aug 2003
    329
    Re: Rhino ST6 CNC Lathe Restoration
Name:	2021-06-04 21.11.07.jpg
    This is a slantbed lathe. It has a maximum turning size of 2".
    Aug 2003
    329
    Attachment 469008
    The original electronics used a DOS based PC. I intend to change all the electronics out for newer equipment. The Centroid Acorn and some Hybrid Steppers.
    Aug 2003
    329
    Attachment 469010
    The Spindle motor is a Baldor 90VDC 1/2HP motor.
    Anyone have any suggestions for how to remove the old paint and rust?
  1. Rhino ST6 CNC Lathe Upgrade
    By Aaron Powter in forum Mini Lathe
    Last Post: 04-30-2014, 01:43 AM
  2. Atlas 10" Lathe Full Restoration + CNC (Project Log)
    By JohnnyVegas in forum Vertical Mill, Lathe Project Log
    Last Post: 10-12-2013, 10:50 PM
  3. Mini Lathe restoration / tuning advice?
    By panofish in forum Mini Lathe
    Last Post: 10-06-2010, 04:57 PM
  4. Enco 9 x 20 Lathe Restoration
    By warossignol in forum Mini Lathe
    Last Post: 04-03-2008, 08:40 PM
  5. interfacing rhino ST6 lathe
    By albert5 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-08-2008, 10:50 PM
