586,655 active members*
2,514 visitors online*
Results 1 to 8 of 8
    Nov 2015
    260
    PWM to Pul/Step Signal.
    Hello. Is it possible to connect the PWM output signal directly to a stepper motor driver. So to the Pul / Step input of the driver.
    It works. But do I have to switch something in between? I don't want to destroy the board.
    Nov 2008
    643
    Re: PWM to Pul/Step Signal.
    No
    Nov 2012
    1266
    A stepper pulse generator board would convert PWM to Step/Dir, if you can find one in the frequency range you need. Connecting PWM directly do the Step input will not give you any meaningful results.
    https://www.aliexpress.com/item/1005002988610764.html
    Nov 2015
    260
    That doesn't get me anywhere. I want to use the PWM signal of the MK3 / 9 controller.
    Dec 2013
    5717
    As long as the controller is outputting a 5V PWM signal it should not damage anything, but I'm not sure how much control you will have over the stepper motor. Normally the PWM signal is fixed frequency with a variable duty cycle, where the normal step output is a variable frequency with a fixed 50% duty cycle.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2015
    260
    If I control it via MDI, it works.
    so:
    M63 P1 Q106
    Then the motor turns once per minute. Because the steps on the driver are set to 6400
    M63 P1 Q6400 would be 1x per second
    I would just like to put a menu in the toolbar where I can then select different frequencies.
    Unfortunately, I don't know the exact syntax for this.
    Nov 2015
    260
    Code:
    cmd: "Machine.Output_PWM" image="BtnBottom/laser-beam.svg" imagechange="true" stroke=1.1 type=menu val="[0;0]@PWM1 0%|[0;25]@PWM1 25%|[0;75]@PWM1 75%|[0;100]@PWM1 100%"
    Unfortunately that does not work
    Because I think the E value is given and not the Q. But unfortunately I don't know.
    Nov 2015
    260
  1. Independent PWM signal output
    By tantemay in forum PlanetCNC
    Last Post: 08-31-2021, 05:10 PM
  2. PWM to 0-10v Signal?
    Last Post: 12-29-2020, 09:19 AM
  3. Change BOB PWM signal to 0-10 V signal
    By Sterob in forum Chinese Machines
    Last Post: 12-21-2017, 01:42 PM
  4. convert 5v PWM signal into analog signal ranges from -10 to +10 v
    By Hamayel in forum CNC Machine Related Electronics
    Last Post: 12-12-2015, 10:05 AM
  5. PWM signal
    By babinda01 in forum CNC Machine Related Electronics
    Last Post: 03-18-2008, 04:39 PM
