586,108 active members*
3,328 visitors online*
    Aug 2021
    Post Coolant fuses blow- Fadal
    Hello,
    I have purchased a VMC 15 XT fadal CNC, the problem that I have is when i activate the coolant from the control, the fuse burns and the pump stops working.
    Do you have some idea about the possible issues for which I have this result
    Thanks.
    Dec 2013
    5717
    Re: Coolant fuses blow- Fadal
    Possible causes: Bad motor, bad wiring, not correct fuses, motor voltage wiring wrong.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2021
    Thanks for your answer,
    I will try to review based on your comments and let you know how my went.
    Thank you so much.
    Quote Originally Posted by induser View Post
    Thank you so much.
    Hey I have the same issue. I keep changing the fuses and it blows right away when I press the Coolant 1 button. The pump works when I plug it into a different power source. And I just swapped out the outlet. What things did you look for or what was your problem?
    Dec 2013
    5717
    Quote Originally Posted by apooch0209 View Post
    Wrong fuses maybe? Fast blow rather than slow blow as they should be for a motor?
    Jim Dawson
    Sandy, Oregon, USA
  1. Fadal Coolant lines
    By rwskinner in forum Fadal
    Last Post: 12-10-2018, 05:43 AM
  2. Phase fuses blow on 6T spindle drive
    By Jerry Shorter in forum Fanuc
    Last Post: 11-11-2009, 10:04 PM
  3. 1.3 amp alarm fuses blow on my Velocity Control Unit
    By gcpmachine101 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-26-2008, 10:17 PM
  4. 1.3 amp alarm fuses blow on my Velocity Control Unit
    By gcpmachine101 in forum Mass finishing equipment/media/strategies
    Last Post: 09-26-2008, 03:52 PM
  5. 5 amp fast blow fuses
    By planescott in forum Gecko Drives
    Last Post: 02-21-2006, 10:06 PM
