586,060 active members*
4,351 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 21i-t function key programming
    Dec 2011
    15
    Anyone know how to program function keys on a 21i-t?
    I would like to run some M codes with them.
    Aug 2019
    145
    Re: Fanuc 21i-t function key programming
    Im not sure which keys you are referring to but;
    M-codes are functions of the PMC. Therefor it would be a fairly easy task to either use spare buttons from the Machine Operators panel (Not MDI /QWERTY key pad), or even to add buttons. Then modify the PMC to activate the functions currently controlled by the M-codes. Using the PMC would also allow any interlocking deemed necessary to prevent accidental activation.
    There is also a function called "Software Operators Panel" which could eliminate the need to add buttons. But their operation is limited.
  1. function of key in control panel
    By nabil_elbadri in forum Daewoo/Doosan
    Last Post: 12-18-2020, 10:27 AM
  2. Replies: 3
    Last Post: 07-27-2018, 03:40 AM
  3. Programming FANUC 21i-TB
    By neroseu in forum Fanuc
    Last Post: 07-25-2011, 01:10 PM
  4. Can I program a key to preform a function?
    By WOTDesigns in forum Mach Wizards, Macros, & Addons
    Last Post: 07-24-2011, 06:29 PM
