586,089 active members*
3,832 visitors online*
    Dec 2011
    63
    That Darn Red LED
    Hello, all. I'll try to keep this simple. I had to build a new PC for my CNC router, using Mach3, a Gecko 540, and a printer card/cable. I'm using the old .xml file that worked quite well. No matter what I do I can't get the Fault LED to go out unless I turn off the Charge Pump Switch. To isolate the problem I disconnected everything from the PC. Only the E-Stop button and the four (4) Home switches... none of which are active.
    I still have the Red LED even if I hit the E-Stop Button and even if I use a jumper between the #10 and #12 points on the Gecko. Would this indicate a bad fuse in the Gecko?
    Thanks for your time.
    Aug 2008
    Re: That Darn Red LED
    Have you verified that the charge pump source is working and that it is wired correctly to the 540?
    If the light goes green when the charge pump switch is set to disable then it seems there is something wrong with the charge pump.
    The E-Stop will not make the light green. That light indicates when the 540 is ready to send commands to the steppers. It certainly will not do that if the E-Stop is active.
    Aug 2005
    1094
    Hi
    Make sure you have “charge pump on in estop” ticked in the Mach3 general config page.
    If you don’t, you’ll end up with a catch-22 problem.
    Mach3 won’t produce the Charge pump as the G540 is in Estop. The G540 won’t come out of Estop as there is no charge pump.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  1. Jp-1635A troubleshooting and red led
    By gmcgough in forum Stepper Motors / Drives
    Last Post: 08-08-2018, 01:22 AM
  2. AM882 solid red led, no green led
    By Tutu in forum Leadshine
    Last Post: 11-09-2017, 04:08 PM
  3. how do i set red/green LED values?
    By kjl-pdx in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-27-2014, 09:23 PM
  4. TEK10 red LED keeps flashing
    By bartL in forum CNC Machine Related Electronics
    Last Post: 10-19-2009, 09:10 PM
  5. help blinking red led and clicking sound
    By mberad in forum Xylotex
    Last Post: 07-09-2007, 04:07 AM
