Hello, all. I'll try to keep this simple. I had to build a new PC for my CNC router, using Mach3, a Gecko 540, and a printer card/cable. I'm using the old .xml file that worked quite well. No matter what I do I can't get the Fault LED to go out unless I turn off the Charge Pump Switch. To isolate the problem I disconnected everything from the PC. Only the E-Stop button and the four (4) Home switches... none of which are active.
I still have the Red LED even if I hit the E-Stop Button and even if I use a jumper between the #10 and #12 points on the Gecko. Would this indicate a bad fuse in the Gecko?
Thanks for your time.
