Hi, I hope this is the right place to ask, sorry mods if it is not, just finding my feet here!
I have just been running a whole bunch of pocketing feed speeds/depths on my 3020 and have come to the conclusion I can cut pockets in MDF at 400mm/min with a 5mm depth of cut without bogging down the 300w spindle (with a 40% stepover).
Is there a rough rule of thumb that I can use this information to work out where to start with working out the contour speeds?
I'm working on the assumption with a contour cut much more of the endmill is in contact with the material = more friction, heat, and higher chip load, so will need to slow the feed or depth down?
