586,058 active members*
4,833 visitors online*
Results 1 to 8 of 8
    Software problem
    I have a dynapath delta 50M control but when i turn on the following messages appear
    "Power fail: part program and setup information must be reload"
    And
    "Cycle power to continue. Watchdog timer si tripped"
    Re: Software problem
    Quote Originally Posted by Mikeordaz View Post
    And
    Looks like hardware problem caused this problem.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2009
    1982
    Watchdog points to hardware problem. Software is generating the message, so software is correct. Check the power supply and if the CPU is seated in the socket well.
    Quote Originally Posted by Algirdas View Post
    what are the correct values in the power supply?
    Aug 2009
    1573
    And
    ...check the Battery voltage on the SRAM Card....should be above 3.1vdc. Replacement is easy with add-on battery pack because there 3 Pin plug for battery.
    ...to clear the Watchdog Timer you might need the CNC.EXE Floppy reloaded after Battery updating.
    Quote Originally Posted by machinehop5 View Post
    Where can i get cnc.exe???
    Aug 2009
    1573
    ...Dynapath is still in business, but they will what to sell you a Floppy upgrade $300+CNC exe cost. Call or email them with your Serial Number of the CNC control you have.
    https://www.dynapath.com/services.php
    good luck..and lets us know how much the CNCEXE costs ya, IF you need it.
    DJ
    Sep 2017
    Quote Originally Posted by cncmakers001 View Post
    What was the outcome. I got the same message after we replaced the battery. Very frustrating.
  1. software problem engraving problem please help
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-19-2014, 09:31 AM
  2. Problem with Fastcam software
    By ambc75 in forum Uncategorised CAM Discussion
    Last Post: 11-04-2012, 12:29 PM
  3. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
  4. HS1 software problem I think
    By The CNC Noob in forum Haas Mills
    Last Post: 08-18-2009, 08:34 PM
  5. Computer or software problem?
    By jguerrera in forum CamSoft Products
    Last Post: 11-10-2008, 04:05 PM
