586,113 active members*
3,573 visitors online*
    Jul 2005
    380
    Servo 300 Bar Feeder Blues
    I'm having trouble with my Haas Servo 300 bar feed.
    It's attached to an SL20 lathe.
    Up to a few weeks ago, it was running fine, but now when the pusher rises to allow a bar to drop into the channel, it rockets upward at lightning speed, and slams against the stops so hard, it vibrates up and down and works its way out of the
    cam stop it is supposed to lock into.
    Any idea on how to have this thing rise up in a more controlled manner?
    Thanks.
    -Doug
    Jul 2005
    380
    Re: Servo 300 Bar Feeder Blues
    Found the issue - finally.
    Haas bar feed parameters are on a sticker located on the feeder itself. Problem solved.
  1. Replies: 1
    Last Post: 07-06-2020, 05:17 PM
  2. SERVO 300 FEEDER SPEEDS
    By WGJ in forum Haas Lathes
    Last Post: 01-07-2020, 09:21 PM
  3. Inconsistent Haas 300 bar feeder
    By Dweezle69 in forum Haas Lathes
    Last Post: 07-14-2011, 06:42 PM
  4. Servo bar 300 bar feeder
    By dthiede in forum Haas Lathes
    Last Post: 08-27-2010, 01:35 PM
  5. Servo 300 Bar Feeder
    By wudbutcher in forum Haas Lathes
    Last Post: 08-24-2010, 04:17 PM
