586,069 active members*
3,307 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Setting up Fusion 360 to run older Matsuura mill with tool changer
    I have a 1981 Matsuura mc500 Mini Master I recently purchased. Still having some issues getting it running due to an error but thats another story. I am currently using Fusion 360 to design in and run my cnc plasma table. The previous owner used an older version of Mastercam to run the mill when he had it. I have never tried using Mastercam before. Can fusion 360 be used to run this old machine and get the tool changer to function as well? This is my first cnc mill and I am trying to figure out what I need to do to get it running. Thank you
    Apr 2020
    53
    Re: Setting up Fusion 360 to run older Matsuura mill with tool changer
    You will need a post processor from Fusion that will work with your machine. You can search their library here
    https://cam.autodesk.com/hsmposts
    I was in the same boat a few months ago and luckily for me Fusion had one in their system as standard for my Acaramatic control.
    You will probably need to fiddle with some settings, but thats a buit further down the road.
  1. matsuura mv 500 (1981) tool changer help
    By PatrickF in forum CNC Machining Centers
    Last Post: 03-12-2022, 04:09 PM
  2. Computer to run CAD, Fusion 360
    By Gunmachinist in forum Autodesk CAM
    Last Post: 02-28-2021, 04:43 AM
  3. Fusion 360 or PP tool table
    By idtat in forum Tormach Personal CNC Mill
    Last Post: 10-03-2017, 11:56 PM
  4. Replies: 11
    Last Post: 08-23-2017, 03:46 PM
