586,075 active members*
4,261 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB15 - OSP5000 / DNC / Serial transfer.
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Apr 2009
    1262
    Re: Okuma LB15 - OSP5000 / DNC / Serial transfer.
    The green screens were not L-G controls but were L controls typically. Is yours for sure an L-G ? Ie does it have animated graphics and not just the Trace? Communication protocol is different on the two controls.
    Experience is what you get just after you needed it.
  2. #22
    Nov 2013
    152
    The control says OSP500L-G. Guy I bought it from said it’s a 1986 LB12. It definitely has the green monochromatic screen. I haven’t found any graphics or trace. The machine is new to me. I’d really like to get the serial Read working. Any help is much appreciated.
    I’m using an Ausys DNC PRO. If there’s another working combo I’m willing to change my setup. I am able to Punch to the DNC Pro just fine. With all sorts of different settings.
  3. #23
    Aug 2009
    1573
    Quote Originally Posted by slodat View Post
    I'm having a heck of a time getting my OSP500L-G green screen LB12 to communicate via RS-232. I can send from the control to the DNC Pro and it works every time. I can a myriad of errors whenever I try to send even a 3 line file DNC Pro -> control. I've read a lot of threads on here, spent many hours experimenting, and I'm at a loss.
    Is anyone knowledgeable about the older Green screen configuration? I'd really like to send programs to the lathe.
    ...If, you are able to Download from CNC to PC...but not the other way then I would say there is a Format error of beginning of the Part Program you're trying to Upload.... try starting the Program with a BLANK line #1...on Line #2 a "%" a Percent Sign may or may not be needed at End of the program also....Seq Numbers may or may not be needed.
    Post a Sample program you have would help.
    DJ
  4. #24
    Nov 2013
    152
    I am unable to transfer a file I got from the control back to the control.
  5. #25
    Mar 2009
    1982
    if you can compile clear detailed description. I am lost. So you transfer the file from one machine to another or what?
  6. #26
    Aug 2009
    1573
    Post the File you transferred
  7. #27
    Nov 2013
    152
    RS-232 cable is built according to this sheet I found on here:
    Attachment 494186
    1986 Okuma LB12 with OSP500L-G control. Bootup screen:
    Attachment 494188
    Parameters:
    Attachment 494190
    Attachment 494192
    Attachment 494194
    This is what I get when I try to transfer from PC to CNC. (PC is an Ausys DNC Pro):
    Attachment 494196
    This is what I get when I transfer CNC to PC:
    Attachment 494198
    This is the file that I transfered from CNC to PC. I am unable to transfer the same file PC to CNC. I hand keyed this program into the control.
    Code:
    $T3.MIN%
    G50S3500T0101
    G96S3000M4
    G0X.76 Z.2
    G1 X-.1 F.004
    G0 Z.1
    G0 X.76
    G0 Z-.03
    G1 X=-.1
    G0 Z.1
    G0 X.72
    M2
    I have tried several different settings, etc. I can always transfer CNC to PNC. I have received a litany of different errors, to no avail. The OSP500L-G that I own does not accept a baud rate number is Optional Parameter Word 39. It's set to 0 as shown in the images above.
  8. #28
    Aug 2009
    1573
    ...try adding % to the 1st Line of your program...if, that doesn't work. add a Blank line (CR/LF) to the 1st Line then, with the % on the 2nd Line...then your posted program just the way it is..
    edited-
    $T3.MIN%
    G50S3500T0101
    G96S3000M4
    G0X.76 Z.2
    G1 X-.1 F.004
    G0 Z.1
    G0 X.76
    G0 Z-.03
    G1 X=-.1
    G0 Z.1
    G0 X.72
    M2
  9. #29
    Dec 2008
    3109
    $T3.MIN% <<<<<..... get rid this line
    G50S3500T0101
    G96S3000M4
    G0X.76 Z.2
    G1 X-.1 F.004
    G0 Z.1
    G0 X.76
    G0 Z-.03
    G1 X=-.1
    G0 Z.1
    G0 X.72
    M2
    The 1st % let's the control begin recording the start of code to be saved, the $ indicates the name to be saved as in the control (filename can be altered on "READ" line)
    Last (2nd) % is used to terminate the transfer and close the file.
    So....
    - One % at start AND one at end ...only
    - Remove the file naming part (after $,before 1st %) to assist diagnosis of xfer issues.
    Not sure of the earlier models, but.... there is different settings for READ and PUNCH. Both areas need to be checked.
    Same goes for the xfer software on the PC. It also may have independent settings.
  10. #30
    Nov 2013
    152
    Tried that
    2504 no tape data ERROR
    Top of screen does show READ A.MIN
    And, thank you for your help! Really appreciate it.
  11. #31
    Nov 2013
    152
    Changed bit 1.5 and now it locks up. So, that's not it!
  12. #32
    Mar 2009
    1982
    what does it mean "locks up" ?
    I would say using the minimal cable is bad idea at this case. Handshake lines are shortened, so you don't get any idea about handshake. So does OSP and doesn't say any error message.
    By the way the picture at the comment #9 is showing wrong wiring as well.
    Check the comment #5
Page 2 of 2 12
  1. okuma lb15 wilt osp5000 moves only in one direction
    By Reyad in forum Hobbycnc (Products)
    Last Post: 09-24-2020, 03:29 PM
  2. Free DNC RS232 software for serial file transfer
    By bborb in forum DNC Problems and Solutions
    Last Post: 10-11-2016, 02:18 PM
  3. Replies: 13
    Last Post: 08-16-2016, 10:52 AM
  4. LB15 with OSP5000 monitor
    By geeserteg in forum Okuma
    Last Post: 12-09-2009, 11:20 PM
