586,075 active members*
3,803 visitors online*
Results 1 to 8 of 8
    May 2016
    15
    Lathe spindle encoder drive
    I picked up a 600 pulse quadrature encoder for the 1720XMTC, and I'm scratching my head on how to drive the thing. What have others done?
    I'm thinking driving it from the gearbox output which runs at half or quarter spindle speed is the only option.
    Looking for ideas.
    Sent from my SM-G950U using Tapatalk
    Jan 2010
    17
    Re: Lathe spindle encoder drive
    I attached the encoder to the backside of the spindle.
    May 2016
    15
    different machine. I have a chunky stepped pulley in the way.
    Dec 2013
    5717
    My spindle encoder is driven directly from the spindle at 1:1 using timing pullies and a belt.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2013
    5717
    Looks like you have a bit of spindle sticking out there that you could either screw a timing pulley onto or a stub shaft and slide a timing pullet onto. Either way it looks like the most reasonable way of doing it.
    Jim Dawson
    Sandy, Oregon, USA
    If you can't get quite enough threads to extend it from what sticks out, you can maybe thread a stub shaft on instead of the shaft nut, so long as you match the critical features on the nut.
    Better than drilling holes in the heart of the pulley and possibly initiating cracks.
    May 2016
    15
    Quote Originally Posted by StrawberryBoi View Post
    That sounds workable. The locknut uses all the thread and the spindle end is farther in than the pulley.
    I'd also need a longer drawbar.
    Jan 2010
    17
    I would check with a company that sells magnetic linear scale tape, maybe they make something that could replace the magnetic sensor on the face of the pulley. If so, it would stick on the face and you could use the existing sensor bracket for a higher resolution sensor.
  1. Spindle Encoder options for a Smithy Lathe
    By Crusader8968 in forum CNC Machine Related Electronics
    Last Post: 05-21-2020, 12:02 PM
  2. spindle encoder for lathe
    By anowrosh in forum Mini Lathe
    Last Post: 02-11-2018, 11:03 PM
  3. Spindle encoder Haas Mini lathe delivery
    By marto74 in forum Haas Mills
    Last Post: 05-25-2012, 02:53 PM
  4. spindle dc servo / encoder, lathe
    By hutchison in forum Machines running Mach Software
    Last Post: 04-05-2009, 03:48 PM
  5. Need an encoder for my C3 lathe spindle.
    By alexccmeister in forum Shopmaster/Shoptask
    Last Post: 08-07-2008, 04:56 AM
