587,030 active members*
3,981 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > spindle speed fluctuations and not max speed
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Sep 2021
    11
    Re: spindle speed fluctuations and not max speed
    good evening mactec54. Today I tried to measure what you advised me, but I have no tension anywhere. Which cable exactly should I measure? I measured 10v and ground. voltage but only max 1.2 volts :/
  2. #22
    15362
    Quote Originally Posted by hociSK View Post
    You should only be measuring the output from the Breakout Board, not any cables, if 1.5v then you have a problem with the setup in the control or your Breakout Board is bad, these Breakout Boards have not been very good and most have this same problem with the spindle speed output voltage
    Have you connected the 12/24v to the Breakout Board , 12v is normally best
    Mactec54
Page 2 of 2 12
  1. waterjet cutting speed fluctuations
    By deadlykitten in forum Waterjet General Topics
    Last Post: 06-14-2016, 07:12 AM
  2. Default Max Spindle Speed
    By rckdef in forum BobCAM for SolidWorks™
    Last Post: 12-30-2013, 05:46 PM
  3. Setting Max Spindle Speed ST-20
    By jheers in forum Haas Lathes
    Last Post: 10-17-2012, 10:11 PM
  4. Max spindle speed Tsugami BW-07
    By LATHEGIRL in forum Fanuc
    Last Post: 05-31-2012, 10:50 PM
  5. What max spindle speed should a mill have ?
    By nashtm in forum Benchtop Machines
    Last Post: 08-05-2005, 08:26 PM
