586,055 active members*
4,376 visitors online*
    Jun 2009
    4
    Switching from MK2 to MK3
    When we priced out going with a Planet CNC controller, we only knew of the board cost then once we had bought it we found out about the license cost and then again later found out that the board could only actually run a VFD if we bought another daughter board and paid for international shipping on that too. After 6-7 years of running the MK2 board and many changes to your software, there are a bunch of annoying bugs that got introduced later on with things like slider bars having useless scales and the MPG pendant not working so I would like to upgrade to Planet CNC TNGv2 so the bugs can hopefully go away and I can get the pendant to work.
    What do I need to buy to upgrade the software? I see that my MK2 board isn't going to work for this new program so I will need a MK3 board at a minimum. Can my old license transfer over? The MK2 won't be needed anymore anyways.
    Is it of any advantage to use Ethernet over USB? I'm currently using the double shielded USB cable from you guys. It seems like most cables can just be unplugged and moved over without any problems.
    Any advise is appreciated.
    Re: Switching from MK2 to MK3
    Quote Originally Posted by jacobbiljo View Post
    you have the mk2 want to sell me it
  1. Relay on MK3/4DRV
    By haax in forum PlanetCNC
    Last Post: 04-07-2021, 08:44 PM
  2. Replies: 1
    Last Post: 01-05-2020, 12:40 PM
  3. MK3/4 to PoStep60
    By RBuster in forum PlanetCNC
    Last Post: 02-01-2019, 01:30 PM
  4. Mk3 inputs.
    By MrEmo in forum PlanetCNC
    Last Post: 01-17-2018, 04:34 PM
  5. Powering Mk3/4
    By theRat in forum PlanetCNC
    Last Post: 09-17-2017, 01:16 PM
