586,069 active members*
3,680 visitors online*
Thread: fanuc 18T
Results 1 to 5 of 5
    Sep 2005
    274
    fanuc 18T
    the measure soft key don't work, say I was indicating a drill and key in X0 measure it sets the geometry to 0 and not the real number, it has a the input C soft key, this is on a deawoo puma 200 with fanuc 18T, ive ran a lot of pumas and the measure soft key always worked. some old hardinge guy who no longer works here got his fingers in the parameters trying to make it act like a hardinge old school crap, he didn't even use the tool eye? , also reset don't dump the offset? any help would be great
    Apr 2017
    29
    Re: fanuc 18T
    Try this . Key in X0 then press the Position Record Button Then Press the Measure soft key
    Aug 2019
    145
    Re: fanuc 18T
    There are several parameters that affect how reset works with offset. I might suggest looking at a machine that works the way you want and compare those
    Parameters using a parameters manual.
    Example 1202.3 is whether reset clears local cords. system. 5003.6 tool offset value is cleared or not. etc.
    There are a few that could affect operation.
    There are parameters for measure as well.
    Sep 2005
    274
    Re: fanuc 18T
    Yep the button worked, and I did find the parameters I needed to change, everything works as it should. thanks for the help!
    Re: fanuc 18T
    How is it possible to change this behavior? Not using the position record button every time.
  1. Replies: 12
    Last Post: 12-26-2016, 10:31 PM
  2. Fanuc 18T
    By M.RISHIKESH in forum Fanuc
    Last Post: 06-26-2013, 04:10 PM
  3. fanuc 18t
    By mckamachine in forum Fanuc
    Last Post: 08-17-2009, 01:59 AM
  4. Fanuc 18T
    By Paul in OK in forum Fanuc
    Last Post: 03-03-2008, 11:06 PM
  5. Ge Fanuc 18t
    By positiverake in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-07-2006, 12:13 AM
