586,036 active members*
3,715 visitors online*
    Talking UNEVEN PROFILE STONE POLISH
    Hi there i'm really hoping someone has either had some experience with this or potentially has a fix or even some insight into this. I'm running an older CMS Concept213 CNC for mainly doing Sink cut outs and Edge polishing for standard Island styled Counter tops and on the edge that goes against the reference points the edge always seems to be far to sharp on the Top side and the opposite edge from the reference points the machine always seems to "Over polish" leaving a wavy line and comes in to far effectively meaning I have to cut the Counter top down and manually polish it. Just wondering if this could be because the vacuum pods are uneven in size or if it has to do with possibly the CNC bed becoming out of Level or even potentially something to do with the spindle. Any sort of information on this would be greatly appreciated
    Cheers!
    Nov 2012
    1267
    Re: UNEVEN PROFILE STONE POLISH
    Judging by your description, you do have a leveling problem somewhere. A dial indicator will help you find where exactly the problem is. Could be unleveled bed, could be uneven vacuum pods, could be uneven thickness or warping of the countertop itself.
    We thought the uneven Stone thickness could of been the issue but have trialed Milling down the stone with a 90mm Stubbing wheel and gauged it all to the same thickness.
    Thanks for the input!
  1. Stone engraving machine: The spring of stone applications
    By Tongxing in forum Education - Teachers and Students Hangout
    Last Post: 09-10-2015, 10:12 AM
  2. can not complete my profile due to sheet warping and uneven flatnesss
    By fsa in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-06-2014, 12:28 PM
  3. EDGECAM PROFILE CYCLE GIVES ME UNEVEN TOOL PATH
    By prasad_slb in forum EdgeCam
    Last Post: 05-20-2013, 05:29 AM
  4. profile glass on a stone cnc.
    By dustpan in forum Glass, Plastic and Stone
    Last Post: 06-01-2010, 01:59 PM
