586,116 active members*
3,343 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Heidenhain 355 controller
    Good morning,
    I have recently purchased an old bridgeport machining centre which has heidenhain contol. The controller is a TNC 355.
    I am currently using TNC server (a heidenhain program) to drip feed the program into my machine.
    The issue i am facing is that it will quickly state "wrong data input" on my machine after only a few lines of program.
    I have been told that my program data needs to start and end with a particular code or number for the machine to recognize? of which i am not sure.
    Also, i am using solidcam post processer which only gives me and option to export it into a H file of for TNC 426 controller , could this be the issue? Does my 355 controller need read the program data differently ?
    Any help would be greatly appreciated.
    Thankyou guys.
    Max
    Sydney AUS
    Aug 2009
    1573
    Re: Heidenhain 355 controller
    ...Search for "HEIDENHAIN TNC355 service manual" I see something about "Blockwize Transfer" MP223 would be 1 and for "Standard interface" set to 0. Look in Chapter 11 for more settings.
    good luck
  1. Heidenhain TNC 355 pinout
    By jaroslava in forum HEIDENHAIN -> TNC
    Last Post: 02-13-2021, 03:04 PM
  2. HEIDENHAIN TNC 355 PARAMETERS
    By Arjuna in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-17-2019, 11:57 AM
  3. Beaver Partsmaster Heidenhain 355
    By Dabman in forum HEIDENHAIN -> GENERIC
    Last Post: 02-24-2019, 10:36 PM
  4. Asking for post for heidenhain 355
    By clemenzza in forum Post Processors for MC
    Last Post: 12-09-2015, 11:49 AM
  5. Heidenhain LE 355 B Parameter Advice
    By overbomber in forum DNC Problems and Solutions
    Last Post: 10-26-2015, 12:58 PM
