586,035 active members*
3,712 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynapath > odd problem missing blocks with Buffered Input...aka DNC drip feeding a Dynapath 50MU
    Aug 2009
    1573
    ...discovered a odd problem when using the Buffered input on a Dynapath 50MU....the problem seems to be affecting only the last 200-300 blocks at the end of every program I've tried. The blocks are missing. This also happens when Transferring programs to the Dynapath's HDD or to the FDD via Serial Port with Bobcad 23 Predator CNC software and using a Moxa 5210A serial to IP unit....but when transferring to the Part Program memory of the Dynapath works fine, but limited to 192k
    ...I'm thinking this maybe a early Dynapath 50MU bug
    Aug 2011
    121
    Re: odd problem missing blocks with Buffered Input...aka DNC drip feeding a Dynapath
    So this chops off 200 to 300 blocks regardless of program size? Are you outputting Dynapath or EIA code? Could you add 300 blocks after the M30 just to see if it would get you to the end of your program? Alternatively, you could try 300 G0 moves with X0/ Y0/ Z0/ before the M30.
    RT
    Aug 2009
    1573
    ...Hi RT,
    .. found the problem...for some reason the Moxa 5210A unit is dumping the last 200-300 blocks. It maybe something is not set correctly but, I tried for days (pull hair here) every setting possible was driving me nuts.
    https://www.moxa.com/en/products/ind...es/nport-5210a
    .. switched to a old Quatech SSE-100D unit and the Buffered Input and file transfers work perfectly now at 19.2k.
    https://www.ebay.com/sch/i.html?_fro...h+dd&_osacat=0
    Quatech had website support a year or two ago but, I can not find it right now...or maybe they are out of business now.
    https://www.bb-elec.com/Tech-Support...r-Drivers.aspx search SSE-100D...I see they have Linux drivers too
    DJ
    Aug 2011
    121
    Good thing you had a backup!
  1. Drip feeding fadal : DNC or DNCX
    By Shizzlemah in forum Fadal
    Last Post: 03-10-2019, 08:32 PM
  2. Has anyone ever tried using an rPi for DNC drip feeding?
    By GerryG in forum USB, RS232, PARALLEL etc
    Last Post: 09-28-2018, 01:19 PM
  3. Drip feeding DNC to Fanuc 6M
    By Camfather in forum Fanuc
    Last Post: 04-21-2017, 03:50 PM
  4. J 325 bufferd input (Drip Feeding)????
    By red zilla in forum Tree
    Last Post: 07-30-2012, 10:28 PM
  5. dnc-drip feeding, delta 20
    By MadPickinSkills in forum Tree
    Last Post: 06-23-2011, 04:18 AM
