586,116 active members*
3,392 visitors online*
    Jun 2021
    drawing a rectangle in cut2desktop
    have drawn a rectangle in cut2desktop,completed full process, then downloaded through UCCNC to my 6040 CNC, run file ,watching XY dimensions whilst and they seem to have my measurements [150x100mm] on screen ,but when i trace a pencil line on spindle head, the dimensions are approx 30mm both ways bigger [180x130mm] can someone explain why thanks
    Jun 2010
    4256
    Re: drawing a rectangle in cut2desktop
    Very simple: your axes are not properly calibrated.
    Or you have mixed the units (cm & inches) up somehow.
    Cheers
    Roger
    Nov 2021
    Quote Originally Posted by johnhow View Post
    have drawn a rectangle in cut2desktop,completed full process, then downloaded through UCCNC to my 6040 CNC, run file ,watching XY dimensions whilst and they seem to have my measurements [150x100mm] on screen ,but when i trace a pencil line on spindle head, the dimensions are approx 30mm both ways bigger [180x130mm] can someone explain why happy mod
    thanks
    i have the same probem like you.
    Make sure you are using the correct Post processor
    1228
    What tool diameter did you specify?I don't now the machine or the software but if the possibility is there for the computer or the controller to select the correct tool compensation,was the correct selection made?
  1. rectangle pocket
    By strokerace in forum HEIDENHAIN -> TNC
    Last Post: 07-28-2011, 10:00 PM
  2. Replies: 5
    Last Post: 02-24-2011, 10:43 PM
  3. Editing a two sides of a rectangle
    By greenene in forum Mastercam
    Last Post: 06-26-2010, 03:52 AM
  4. NEWFANGLED CUT RECTANGLE
    By BOBINETTE in forum Mach Wizards, Macros, & Addons
    Last Post: 01-13-2010, 01:01 AM
  5. G68 + Rectangle Cycle
    By Shizzlemah in forum Fadal
    Last Post: 01-26-2006, 11:17 PM
