586,103 active members*
3,426 visitors online*
Thread: Machine Zero
    Oct 2013
    34
    Machine Zero
    Hi
    We have a Taiwan Takisawa 110 lathe with system fanuc series 21i-TA
    the issue with it now is that when we changed the batteries in the machine, the machine zero point has been moved
    how do we change the machine zero point manually?
    I have a similar problem with my machine and it uses Fagor software hope some one can help
    Mar 2009
    1982
    Re: Machine Zero
    Did you checked all the rest machine settings? It's very easy to lose all parameters when replacing the battery wrong way on Fanuc 21i-TA.
    Oct 2013
    34
    Re: Machine Zero
    all the machine settings looks fine, exept the x-axis is wrong with about 30mm on the diameter. We dont know which parameter you can change that on. so we are wondering if anyone know which one?
  1. Replies: 0
    Last Post: 08-30-2018, 11:49 PM
