586,060 active members*
4,328 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma OSP300 system variables
    Jun 2004
    7
    Hi all,
    Has anyone got a complete list of system variables, (VS), for the Okuma OSP300 control they can pass to me please.
    I'm trying to control the tool measure in cycle for new tools via the "USE" toggle.
    Cheers in advance
    Alan
    Aug 2011
    419
    Re: Okuma OSP300 system variables
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    hy if you look for VS+ :
    ... a-z, then check attached list of system variables
    ... 0-9, then you will need to dig the msb files, or look through the manuals; those are not system variable, but kind of a mix type, between common/array and local; however, they allow acces to data for measuring cycles and probes, allowing one, for example, to custom build a gauging cycle
    for more details, please be specific / kindly
  1. # on Okuma OSP300
    By ablackwell in forum Okuma
    Last Post: 06-09-2021, 06:48 AM
  2. Okuma System Variables
    By frameguy99 in forum Okuma
    Last Post: 11-04-2020, 08:28 PM
  3. Replies: 7
    Last Post: 10-08-2018, 04:25 PM
  4. Okuma Genos with OSP300 using IGF
    By hutch07 in forum Okuma
    Last Post: 02-02-2018, 07:28 AM
  5. pls, a post for okuma mb66vb osp300 ?
    By deadlykitten in forum Uncategorised CAM Discussion
    Last Post: 06-22-2017, 10:11 AM
