586,108 active members*
3,133 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan TT1800SY TURRET ALARM
    Jul 2021
    5
    Please help need info for clearing #2118 turret unclamp status alarm, turret will not index after changing tool crash
    Feb 2013
    788
    Re: Doosan TT1800SY TURRET ALARM
    Norm,
    We covered a lot over the phone, but I'll summarize here for any passerby that reads this.
    Using K5.4 when in the appropriate Upper/Lower selection
    =1 causes unclamp
    align closely, but not perfect
    =0 clamps, and hopefully causes a slight rotational "jerk"
    If jerk occurs, =1, =0 and should "tick" the last 1%
    If tick, =1, =0 and it should not even feel like a "tick"
    Now it is PERFECTLY centered on the curvic surface.
    Verify that the VPF.M or LVPF.M (for the upper and lower respective turrets) are active
    If they are, then check the geometry as shown in the following video:
    https://youtu.be/7Ucg2v3jEgs
    if not, use the instructions in the Blue Book (located in the pocket welded into the inside of the electrical cabinet's door) to do an ORIGIN SET
    Org.S (origin set) looks like Or9.5 in the instructions because that is what it looks like on the 7-segment display of the drive.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  1. Turret problem doosan 2500 sy alarm 2047
    By vtools in forum Daewoo/Doosan
    Last Post: 07-26-2023, 07:21 AM
  2. Doosan tt1800sy
    By jim2970 in forum Daewoo/Doosan
    Last Post: 09-14-2020, 04:01 PM
  3. Doosan DNM5700S mills and Doosan TT1800SY machines
    By Green0 in forum Daewoo/Doosan
    Last Post: 09-09-2020, 12:30 AM
  4. Doosan Puma TT1800SY - APC "Alarm" on start up
    By Saranac in forum Daewoo/Doosan
    Last Post: 06-28-2015, 03:07 AM
  5. doosan 2020 turret alarm
    By sebturbo2000 in forum Daewoo/Doosan
    Last Post: 08-28-2009, 09:03 AM
