586,060 active members*
4,328 visitors online*
    May 2005
    64
    Fanuc Spindle drive fault
    I have a daewoo 6HS, circa 1986, with a Fanuc 11T control system using a spindle drive number A16B-1000-0693.
    When I push the control ready button, it will not latch, and I get a spindle LED indicator. On the drive board, there is a row of four LEDs labelled FAULT 8,4,2,1. We currently have 8,2,and 1 lit. I contacted Tennessee Industrial Electronics, and they tell me that 8,2,1 is fault code 11, "DC link HI Volt".
    This is pretty much all I can get from TIE.
    We have seen aluminum electrolytic capacitors fail in other control systems after they are around 15 years old. We're leaning towards this as the problem.
    I have manuals for the Daewoo, and manuals for Fanuc 11 controls, but do not have a schematic specific to this component.
    Does anyone have access to specific scematics for fanuc?
    Has anyone experienced this fault on this series of spindle amp?
    May 2005
    64
    oops, correction, spindle drive number a20b-1000-0693
    Jun 2007
    43
    I do not have my books with me at the moment, but did they mean excessive current flow (not voltage), in the DC link. If so, the chances are a blown transistor.
    Feb 2007
    38
    Usually AL-11 is high voltage to the drive. If you have another ~0693 you can swap it with this drive.
    If the problem is AL-12 then DO NOT swap the top board. That usually indicates a blown transistor or shorted motor.
    There are some other factors for AL-11 but better check the board 1st.
  1. Replies: 9
    Last Post: 10-29-2011, 02:02 PM
  2. Hass VF-0 Spindle Drive Fault Q's, HELP!
    By Ryan Moore in forum Haas Mills
    Last Post: 05-31-2007, 10:45 PM
  3. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
  4. Fanuc spindle drive
    By mrwhittle in forum Fanuc
    Last Post: 03-29-2007, 11:28 PM
  5. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
