586,108 active members*
3,328 visitors online*
    Cincom l32 programming
    I have just started program this machine. I am doing a g76 thread cycle but haven't got the manual I have G76 P010060. I know what the 3 values usually do, but I seem to be able to put 00 - 04 in for the the second set of digits. If I put anything else in the machine throws up a chamfer error. I thought I could put 15 in there and that's 1. 5 multiplied by pitch or does this cycle work different on citizen machines.
    304
    Re: Cincom l32 programming
    Quote Originally Posted by BIllcar2006 View Post
    P010060 sets 3 things
    - first 2 digits is the amount of finish passes - 01
    - second 2 digits is % of the lead or pullout exiting the thread- 00
    00 = almost no angle at pullout and 99 = 9.9 leads away start out
    - third 2 digits are the angle of infeed - 60
    0,29,30,55,60,80 are usable (0-90 is ok)
    The actual cutting infeed =(value/2)-.5 so a value of 60 = 29.5 infeed
  1. Old Cincom L16, Quick start guide for programming and machine setup.
    By roberto123 in forum CNC Swiss Screw Machines
    Last Post: 04-04-2021, 06:44 PM
  2. Citizen L32 programming question on using G75
    By jimwjr89 in forum CITIZEN Machines
    Last Post: 11-12-2020, 04:00 AM
  3. Citizen L32 Turning help
    Last Post: 09-11-2020, 08:53 PM
  4. Mazak L32
    By Deltaandy in forum Tormach Personal CNC Mill
    Last Post: 09-02-2020, 08:50 PM
