586,069 active members*
3,425 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > High electrode wear and instable burn with thin electrodes on my DIY EDM machine
    Mar 2016
    my newly selfbuild simple R/C EDM machine works well with 'normal' sized electrodes.
    But with my needed slim sheets it only burns very instable and the wear is unacceptable (up to 300% vs Stainless steel (1.4571,V4A)) high.
    The last thing I know to try is milling round E-Cu57 (sheet copper is a different grade?!) rods to sheets, finding the right graphite or try tungsten copper.
    Has somebody any hints for me or is the only possibility for me to build a better pulse EDM ?
    Does anybody know a good description for a pulse EDM matching my demands? (I have the pulse-EDM Book of Ben Fleming but its very complex without a microcontroller)
    To make yourself a picture of my machine, my problems and my demands here is a YouTube Video:
    Thanks for your interest and with best wishes
    Ralf
    Sep 2018
    5
    Re: High electrode wear and instable burn with thin electrodes on my DIY EDM machine
    I spent a few years as a toolmaker using standard manual and CNC EDM machines. There is a reason why fine detailed work needs more control than just your simple R/C setup. Fine work requires precise control of on and off times as well as current, voltage, frequency and polarity. If you simply want to burn out a tap then R/C will probably do. Fine high surface finish work is going to require some pain if you want to build a controller yourself. There is no way around it. It's a complex field with many variables. There are no shortcuts. Congratulations on what you have done so far. A great effort.
    Oct 2021
    Maybe try using edm 244 oil instead of water? Just a suggestion. Also try and add more flushing. Discharge can build up causing erratic burning.
  1. SKM K60 Electrode EDM
    By goran88 in forum EDM Discussion General Topics
    Last Post: 06-28-2019, 08:00 AM
  2. Do high feeds and speeds wear out a CNC milling machine?
    By dent424 in forum Uncategorised MetalWorking Machines
    Last Post: 06-20-2013, 09:27 AM
  3. Help with sinker edm electrode
    By richrod in forum EDM Discussion General Topics
    Last Post: 07-22-2009, 01:55 PM
  4. edm electrode question
    By lukey in forum EDM Discussion General Topics
    Last Post: 12-13-2008, 05:27 PM
  5. multi-hole edm tube/ electrode
    By elninio in forum Waterjet General Topics
    Last Post: 02-14-2008, 10:09 PM
