586,067 active members*
5,437 visitors online*
Results 1 to 8 of 8
    Feb 2005
    85
    Mach4 G-Code Loading Problems, TXT vs TAP files
    Why does. Mach 4 “Load G code” action now only allows .TAP file type files to be loaded ?.
    TXT files are not even shown in MACH4Hobby/GcodeFiles directory.
    Dec 2013
    5717
    Re: Mach4 G-Code Loading Problems, TXT vs TAP files
    A G code file is in plain text, so just change the .txt extension to .tap Or Save As .tap file.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2013
    4373
    on the Control/General tab of the Mach4 Control plugin, near top right allows you to nominate known or recognised Gcode file extensions.
    Mach4's default is .tap and .nc. If you wish for Mach4 to recognise .txt files then just add it to the list.
    Craig
    Jan 2018
    1516
    Yep.
    On a couple of occasions I've also quickly written a quick code in windows notepad. Then simply changed the .txt extension to .tap and sent it to the machine.
    For the pc illiterate. If you can't see the file extension type you need to:
    Open windows explorer.......
    In upper toolbar click 'Tools' and select 'folder options'.....
    Click the 'view' tab and uncheck 'Hide extensions for known file types'.......
    Now 'Apply'.
    Now you will see the extension type at the end of file names and be able to simply change them as needed.
    Nov 2013
    4373
    by far and away the easiest solution is to use feature supplied by Mach4:
    You can add .txt files and one I find useful is .wtf files!
    Craig
    Attachment 470902
    Feb 2005
    85
    I have no problem changing the file extension from .txt. to .tap.
    However, I did go to Mach4 Control Plugin and added *.txt to the list of accepted file type.
    I copied a couple of test files from my old Mach3 archives to the Mach4 Hobby G Code Files, plus an old text file that I changed to a .TAP type.
    I then restarted the MACH 4 app and selected LOAD G CODE .....
    All of the .TAP files are listed but no .TXT files show up.
    I was able to open the renamed .TXT ( TAP ) and run a test sample
    Also, tried rebooting the computer, still cannot open the .TXT files.
    By the way_ i have several hundred abcd.txt G Code files that I used on Mach 3 for 6 or 7 years, don't want to have to use the file rename thing.
    Nov 2013
    4373
    I have just tried it and it works fine.
    How did you enter the extra entry to the list?
    I just tried this:
    *.tap;*.nc;*.txt;
    Note that the list is ';' delimited and you have to include the '*' wildcard.
    When I made the addition then when I open a file dialogue window the availble and displayed files were of types *.tap, *.nc and *.txt. Note also that this is just the
    preferred file listing, the drop down allows you to choose all file types ie '*.*'
    Craig
    Feb 2005
    85
    Thanks Craig
    Guess I just need to hire a new typist / proof reader !
  1. problems loading old autocad files
    By andrewjs18 in forum Mastercam
    Last Post: 07-30-2018, 07:30 PM
  2. Are there any commands to write a .txt/.tap file from a Gcode?
    By FuriousGeorge in forum Tormach PathPilot™
    Last Post: 08-16-2015, 01:22 AM
  3. loading .txt into centurion 6
    By bestrada11 in forum Milltronics
    Last Post: 04-07-2012, 07:02 PM
  4. problems receiving txt files from cnc (ERTUB)
    By peters1 in forum Controller & Computer Solutions
    Last Post: 04-04-2012, 11:33 AM
  5. G code and tap files
    By geoff3881 in forum G-Code Programing
    Last Post: 01-01-2011, 02:23 PM
