Hey all
Pretty new to the CAM side of the world, just trying to learn a bit when the station is free. I was setting up a simple bracket to hold a microswitch- basically a single piece 1" x .6" with 4 x .08" posts milled from 1/4" 6061 barstock.
I setup the stock as just a boundary box (which would be 1x.6x.25), and then again (in another attempt) as 2x2x.25). The tool is a 1/4" flat end mill. I figured that X2 would have no problem generating a simple path strategy for this part, but I cant seem to find any that work. Yea, I can setup a contour path for each of the 4 pins, and another for the outer boundary, but it seems that I then have lots of islands remaining and the 'rest' milling doesnt seem to handle these islands well. It is frustrating when you see a part that should be very simple to mill confound the toolpath generator- so maybe there are just some weird rules internally about the tool diameter being larger than the pin-edge boundary, etc, but I have had a LOT less trouble generating small/clean paths for complex surfaces than I have with this dumb part. If anyone can take pity on me- what is an appropriate strategy for generating a path for this part?
Regards,
Rob
