586,058 active members*
4,031 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo Recomendations for Avid Pro 4848?
    Nov 2019
    41
    What are people using and what is recommended for servos for an AvidCNC 4848? I will likely be upgrading this to a 4896 within the next 5 years, so I want appropriately sized servos.
    I do production work part time. Say 20 hours a week. I cut primarily wood and some plastic. Occasionally aluminum. I currently run a Joe's Hybrid CNC 4848 with LinuxCNC and Mesa cards. No complaints on the Mesa or LinuxCNC, though open to change. Upgrading to an AvidCNC for improved precision & repeatability as well as stiffness.
    Jan 2008
    1529
    Re: Servo Recomendations for Avid Pro 4848?
    400w servos should be plenty.
    Going smaller is generally not worthwhile as you don't save much $
    I have a Delta BE 750W servo as a small lathe spindle motor. The Delta is excellent, documentation is good and in English, and tuning software is available, easy enough to use and works fine on Win10.
    Cheaper servos as available but once you put any dollar value on your time it is worth paying for Delta or similar (DMM seems to get decent reviews).
    Servos require much more setup and tuning than a stepper and good documentation, and tuning software are essential (unless you have unlimited time and unlimited patience).
    Jan 2016
    69
    One vote for ClearPath servos. Small, powerful, quality, no-drama products. And yeah, tuning software. One phone call away from American engineers who will walk you through and solve problems should you run into any.
    Sent from my iPhone using Tapatalk Pro
  1. Replies: 9
    Last Post: 10-22-2020, 07:45 PM
  2. CRP Pro 4848
    By kappy in forum Want To Buy...Need help!
    Last Post: 03-29-2019, 01:05 AM
  3. Pro 4848 vs Standard 4848 - Total Build
    By pdwatermelon in forum Avid CNC
    Last Post: 06-26-2016, 02:57 PM
  4. Pro 4848 build
    By cbr929 in forum Avid CNC
    Last Post: 11-15-2014, 11:31 AM
  5. Pro 4848 build
    Last Post: 04-16-2014, 12:50 AM
