586,036 active members*
3,844 visitors online*
Results 1 to 7 of 7
    Oct 2021
    3
    Totally newbie question.
    Hi. I'm totally new in G-Code, and maybe somebody can help me.
    I have a Ender-3 Pro 3D printer running Marlin 1.1.6.2 firmware. And I need to use it for a very simple task such as constanly moving Y axis couple of centimeters back and forth when it's turned on. Now I manage to do this with Terminal application by simply sending gcode commands to it. So my question is - maybe therese is a way to use some kind of macro to loop this process? Or even put a file on sdcard so the process would start when I turn on the printer?
    Dec 2003
    1225
    Re: Totally newbie question.
    I know nothing about your specific machine but it is fairly normal for a CNC machine to move all axes a short distance back and forth when switched on to establish the machine's home position by means of a sensor.If it does it several times then you may have a problem,Have you tried seeking help from owners of similar machines?
    Oct 2021
    3
    I'm just looking for general information about g-code, is possible to loop G1 Y2 G1 Y0 with macros.
    Dec 2003
    1225
    Quite possibly,but your code contains some unnecessary information-G1 is modal and only heeds to be there once and being modal,the F rate will carry over from the last instance.If I have ever needed to do this sort of thing I have called up a sub routing using the M98P command and L(number of instances) it can contain any feed rate you choose.Having run as many instances as desired it is cancelled by an M99.Being unfamiliar with your machine,I don't know if this might be a suitable option.
    Oct 2021
    3
    Ok thanks, I'll try.. Maybe you can show me an example of a whole command?
    Dec 2003
    1225
    First you need to determine whether your controller can interpret the command M98P.Is there anything in the manual?
    Nov 2007
    352
    #501 =100( number of repitations)
    While[#501 NE 0]DO 1
    G00 U-10.0 mm ( axis in x will move minus 10 )
    G00 U10.0 (Axis will move 10 plus}
    #501=[#501-1] (count down )
    End 1 (repeat return to start for 100 times }
  1. A very newbie question
    By cancruiser in forum DIY CNC Router Table Machines
    Last Post: 12-29-2014, 12:22 AM
  2. Another Newbie Question.
    By reeser in forum Mach Software (ArtSoft software)
    Last Post: 03-09-2012, 12:46 AM
  3. Newbie Question
    By Ched in forum Australia, New Zealand Club House
    Last Post: 03-01-2012, 11:57 PM
  4. Total Newbie... totally lost!
    By SwarfEye in forum LinuxCNC (formerly EMC2)
    Last Post: 05-31-2009, 05:20 PM
  5. Totally new to this!
    By helenroskil in forum DIY CNC Router Table Machines
    Last Post: 11-17-2008, 09:54 PM
