586,403 active members*
2,312 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Pneumatic Diagram Spindle - feedback
    Sep 2014
    28
    I don't know much about pneumatics. I wanted feedback on this pneumatic spindle diagram. It seems like the 5>2 valve isn't necessary. This was provided by the ATC spindle manufacturer.
    The air requirements and runtime are:
    Dust Removal 3-5 seconds
    Air Seal - leave once spindle is started
    Air Return - 5 seconds
    Air Inlet - only to change
    Jan 2007
    626
    Re: Pneumatic Diagram Spindle - feedback
    5/2 way solenoid valves are used when one side of a device needs to be vented when the other side is pressurised, and vice versa.
    That seems to be what is happening in the diagram, so I think it is required.
    Nov 2012
    1267
    What he said. A 5/2 valve is needed to pressurize and vent a double-acting air cylinder. When one side of the cylinder is pressurized, the other side must be vented so the air could escape. The 5/2 valve does this with a single control signal.
    Sep 2014
    28
    Alright, it just seemed like the solenoid after the 5>2 valve (coming off of A) was redundant. I guess I need to read about each port again to understand what has to happen and when.
    Are these solenoids traditionally triggered by M codes in the g code?
    Nov 2012
    1267
    Quote Originally Posted by district7 View Post
    No, it's not redundant:
  1. Replies: 1
    Last Post: 04-27-2016, 02:20 AM
  2. CNC Spindle with pneumatic chuck Needed
    By paulsaba in forum Uncategorised MetalWorking Machines
    Last Post: 04-20-2015, 01:12 PM
  3. Bridgeport Explorer I Pneumatic Spindle Brake
    By minton in forum Bridgeport / Hardinge Mills
    Last Post: 08-29-2009, 07:16 AM
  4. Pneumatic drawbar, spindle bearings...
    By altaic in forum Mechanical Calculations/Engineering Design
    Last Post: 07-05-2009, 12:34 AM
  5. Electric or pneumatic spindle?
    By swarfmacdaddy in forum MetalWork Discussion
    Last Post: 02-05-2006, 03:23 AM
