586,106 active members*
3,167 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Morbidelli author 503 retrofit for door frames
Results 1 to 3 of 3
    Jul 2014
    3
    Congratulations to all!
    We are engaged in the restoration of the Italian Morbidelli Author 503 1997. for cutting of door frames
    To date, the following has been done:
    1. Customized Drive (Yaskawa)
    2. MACH3 control program
    3. CSMIO -IP / A controller
    4. Number of additional I/O modules CSMIO-IO - 4pcs
    5. Partially written plugin for machine control https://youtu.be/P4YDF4_hjEY
    6. Some comments on the algorithms of the plugin https://youtu.be/-JmDyJRcUBw
    7. We are currently working on the clamps https://youtu.be/jczLTzvCl9Q
    8. Fix/find travers https://youtu.be/23gBTHePuSA
    Maybe someone will have comments on my work, after watching the video, write. Constructive criticism is appropriate
    p.s. My English is bad. But I will try
    Jul 2014
    3
    Re: Morbidelli author 503 retrofit for door frames
    Jul 2014
    3
    Updated software
    Clamps were mounted
    Developed instructions for the DCAM program
    https://youtu.be/XNrnu5zCJYg
    https://youtu.be/d0hrRIeyd8c
  1. Tria 7500 for Morbidelli Author 503
    By stoned in forum Controller & Computer Solutions
    Last Post: 03-28-2024, 07:58 PM
  2. Morbidelli Author 503
    By almakaas in forum CNC Machining Centers
    Last Post: 12-27-2020, 02:57 PM
  3. Morbidelli Author 503
    By num1040 in forum CNC Machining Centers
    Last Post: 07-22-2018, 10:49 AM
  4. Need Postprocessor for Morbidelli author 503
    By carfreak in forum Post Processors
    Last Post: 06-21-2016, 08:51 PM
  5. Software para Morbidelli Author 503
    By neptunet in forum Uncategorised CAM Discussion
    Last Post: 04-04-2013, 03:23 PM
