586,096 active members*
3,635 visitors online*
Results 1 to 7 of 7
    Oct 2021
    Problem with VFD MK100-2S2 HY6040
    Hi all,
    I've bought an hy6040 but I'm encoutering an issue when I try to powerd it up. My VFD screen is blinking with number 0.0, so I can't do anything if I turn the knob to change frequency nothing happend, if I pressed run/stop same isue nothing happend. Is anyone know why my vfd is blinking red? I can enter in programming mode but it semmes I can't change anything.
    Re: Problem with VFD MK100-2S2 HY6040
    Quote Originally Posted by simon88 View Post
    Hi all,
    Hello, have you fix the ploblem. I have the sam one.
    Apr 2022
    135
    Perhaps it has been set for remote control and locked?
    What is the parameters for P001 and p002?
    What is part number and brand for VFD?
    Quote Originally Posted by Vlod View Post
    Hello, thank you. The vfd is mk100.
    The parameters i will check
    P001 has 1 and P002 also 1
    Apr 2022
    135
    I think P002-1 is for terminal control not for the pad of VFD. Check your Mack3 settings as it controls vfd.
    It has all the settings in manual. Did you get mach3 config file for your machine?
    Here is a link to youtube , the guy has all the links there to manual and vfd settings.
    The VFD shows 0.00 as it ready for work and waiting for Mach3 .
    Apr 2022
    135
    Somehow the link was deleted. Just google youtube for hy6040 Mack3 and vfd setup.
  1. VFD manual for MK100-2S2.2G-DK
    By Ktmben in forum Spindles / VFD
    Last Post: 09-21-2022, 01:46 AM
  2. VDF MK100 ...to... MESA 7i76ED
    By Fiury in forum Spindles / VFD
    Last Post: 01-08-2021, 05:50 AM
  3. Err11 on MK100 frequency inverter - Chinese CNC machine
    By NickSpiteri in forum CNC Machining Centers
    Last Post: 07-05-2020, 07:02 PM
  4. Hy6040 5axis CNC
    By KhunKyawOo in forum Stepper Motors / Drives
    Last Post: 05-20-2020, 03:28 AM
