586,119 active members*
3,631 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > NASA's Thermwood 5 Axis CNC Router Retrofit + Siemens SIMODrive 611 + 1FT5 Analog
    Feb 2018
    22
    NASA's Thermwood 5 Axis CNC Router Retrofit + Siemens SIMODrive 611 + 1FT5 Analog Servos + Mach4 + Windows 10
    https://youtu.be/mj6_pfVhihQ
    Mar 2008
    683
    Re: NASA's Thermwood 5 Axis CNC Router Retrofit + Siemens SIMODrive 611 + 1FT5 Analog
    Thanks for sharing.
    That has to be one of the shortest 5 axis gantries I have ever seen.
    Feb 2018
    22
    Clearly, it was designed with a purpose in mind. I mentioned the how the cutting table's size is similar to my own custom built machine, yet this machine is much larger. I would love to get some old photos of what the machine actually made.
    The real takeaway is bringing this hefty machine back to life without having to spend $20k on a new (pentium III) Siemens controller after the old pentium II controller was deemed obsolete.
    Dec 2013
    5717
    That machine looks like it would do some serious work. What controller are you using with Mach4?
    Jim Dawson
    Sandy, Oregon, USA
  1. ERROR A-608 Z axis Simodrive 611
    By Archehead in forum CNC Machining Centers
    Last Post: 02-17-2024, 01:02 AM
  2. Axis Drive Fault VMC 760/22 simodrive 611 and DX32Control
    By FelipeAG in forum Bridgeport / Hardinge Mills
    Last Post: 06-27-2014, 10:00 PM
  3. Siemens Simodrive 611 Faults when cold.
    By beezerlm in forum Servo Motors / Drives
    Last Post: 01-15-2014, 04:15 PM
  4. SIMODRIVE 611
    By borteh in forum Servo Drives
    Last Post: 08-08-2011, 12:22 PM
  5. Simodrive 611
    By jthornton in forum Bridgeport / Hardinge Mills
    Last Post: 06-12-2011, 08:44 PM
