586,106 active members*
3,038 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > L 32 VIII Collet Dwell to allow synchronization device on the bar feeder to engage
    Good morning,
    I would like to know which M-code should I use after collet open to delay the headstock movements in order for the synchro device of the bar feeder to engage properly.
    Lathe: Citizen L 32 VIII
    Bar Feeder: IEMCA Boss 338
    Thank you,
    Dec 2013
    5717
    Re: L 32 VIII Collet Dwell to allow synchronization device on the bar feeder to engag
    Maybe a G4 Pnnnn ?
    Jim Dawson
    Sandy, Oregon, USA
    304
    Quote Originally Posted by mazpuruav View Post
    Good morning,
    Thank you,
    Using the G4U## delay between open and moving could work but you could also fixe the barfeeder parameter to allow more time.
    Iemca parameters #9 & #10 are delays for "Open collet thrust delay", "Close collet thrust delay".
  1. Replies: 1
    Last Post: 07-06-2020, 05:17 PM
  2. Bar feeder oil choices to help with vibration inside the feeder channels
    By lasernerd in forum CNC Swiss Screw Machines
    Last Post: 05-19-2017, 10:59 PM
  3. CAV bar feeder/bar loader--part numbers?
    By calscrew_purch in forum CNC Swiss Screw Machines
    Last Post: 08-17-2016, 07:04 PM
  4. Mori S-15 Bar-Puller/Bar Feeder Parameters
    By MPMInc in forum Hardinge Lathes
    Last Post: 12-05-2015, 05:15 PM
  5. Servo bar 300 bar feeder
    By dthiede in forum Haas Lathes
    Last Post: 08-27-2010, 01:35 PM
