586,189 active members*
4,021 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Cutter Compensation
Results 1 to 7 of 7
    Cutter Compensation
    When I post my code out of Edgecam 2011, the lead move to turn cutter compensation on is posted on the line after the G41 line. Same with the G40 line. Is there a way to get the lead move to show up on the same line as the G41/G40 instead of the next line?
    Keith
    Jun 2015
    4154
    Re: Cutter Compensation
    hy, if you can't fix that, i can create a simple program that will shift the rad comp code at the previous/next/whatever block
    checking to be an inposition, feed, and before it, only rapid movements allowed and whatever else condition you wish ?!
    Quote Originally Posted by deadlykitten View Post
    What type of program will you create. Right now I edit the post in the Edgecam Code Wizard. Will your program look at the compiled post and fix it?
    Jun 2015
    4154
    hy it will edit the program file created by your cam
    Alright, I will give it a try if you're interested. Let me know if you want any $$$.
    Jun 2015
    4154
    okey, i need a few samples : before and after you fix them, so to pinpoint the difference, and write code for it
    for more details, just write a few more posts, until your private messaging will be enabled
    Would you give me an e-mail address that I can send some files to? My e-mail address is [email protected]. I can't figure out how to turn on private messaging. Thanks.
  1. Inte200 MK4 Matrix control - Milling cutter EIA cutter radiusr compensation G41
    By Stavros Flatly in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2013, 02:48 AM
  2. Cutter Compensation D ?
    By Chappyd in forum G-Code Programing
    Last Post: 12-16-2012, 12:32 PM
  3. cutter compensation
    By gotyernumber in forum Fanuc
    Last Post: 09-29-2011, 03:46 PM
  4. Cutter Compensation
    By Terry G in forum Taig Mills / Lathes
    Last Post: 01-29-2011, 05:44 AM
  5. cutter compensation
    By seven3 in forum UG NX
    Last Post: 01-27-2011, 08:55 PM
