586,115 active members*
3,450 visitors online*
    Oct 2021
    Question Is Cracked tube end repairable
    Hi, I wonder if someone could please advise me. Today I switched my laser cutting machine on to cut something (I don't normally do the machine operating, I normally do the designing, so I'm a bit clueless), the next thing I knew there was water everywhere. I searched for the source of the water and found it was spraying out of an hairline crack on the end of the laser tube, photos attached.
    I wonder, can the end bit be purchased and replaced or can the crack be safely filled with some kind of waterproof filler/glue stuff or do I need to buy a new tube. Fingers crossed its not a new tube as this one has only been used for about 40 hours
    Thank you in advance any assistance would be appreciated
    Nov 2008
    643
    Re: Is Cracked tube end repairable
    I would go back to the manufacturer and see if they would replace it. Keep in mind that the red wire is over 20kv and you don’t want to mix that with water. Even if you found a good glue do you want to risk that it springs a leak some day in the direction of that wire?
    Nov 2010
    787
    It is dead. You need new one.
    CNC lasers, constructions, service
  1. K40 whisperer w40 laser tube arching from the end of the tube HELP
    By Antsignsuk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-03-2019, 08:24 PM
  2. How to repair cracked laser tube - epoxy??
    By danielcoyle in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-01-2016, 06:06 PM
  3. any standard design to attach end of a tube to a plate & allow tube rotation?
    By cknicker in forum Mechanical Calculations/Engineering Design
    Last Post: 03-26-2014, 11:19 PM
  4. Tap holes in the end of aluminum tube, Tube will be provided
    By WRichards in forum North America RFQ's
    Last Post: 10-17-2012, 12:30 AM
