586,121 active members*
3,758 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > EMI filters and Yaskawa servo drives
Results 1 to 10 of 10
    Mar 2008
    161
    After a decade hiatus, I have dusted off my Yaskawa Sigma II servo drives and have started laying out a control box.
    Finding the right parts can be a challenge. The Yaskawa documentation recommends 'T' type EMI filters. I must be not using the right search parameters because my searches are not yielding any useful results.
    Do the type of EMI filters really matter for servo drives?
    Thank you.
    Jan 2018
    1516
    Re: EMI filters and Yaskawa servo drives
    Quote Originally Posted by oxford View Post
    Thank you.
    https://www.murata.com/en-us/product...c/chapter06-p3
    Nov 2013
    4376
    'T' type EMI filters have two inductors, crucially one as the first element at the input and one as the last element at the output, and one capacitor between them.
    'PI' type EMI filters have two capacitors, one at the input and one at the output (from the line and neutral) and one inductor in series between them.
    A VFD output has very high frequency switches and they LOATH switching capacitive loads, it causes huge current spikes in the semiconductor devices
    right at the moment of switching which is bad news for reliability. For this reason a 'T' type filter is recommended as the VFD 'sees' the inductor....not the capacitor.
    On the 230V line side of the VFD there is little practical difference between them. At the output of the VFD, that's where the switches are exposed and a 'T' type is required.
    Commonly VFD manufacturers don't recommend EMI filters on the output UNLESS the length of cable between the VFD and motor is over 50' say. Unless you need it I
    wouldn't bother with a filter on the output, but your installation will improve its overall noise performance by having good EMI filters on the 230V input side.
    Given that 'PI' types are the most common, and are perfectly acceptable on the 230V side I would not insist on a 'T' type.
    Craig
    Feb 2005
    750
    Just use the allen bradley's. There are tons on ebay cheap, search for 2090-uxlf-106 (6amp) -110 (10 amp) , -336 36 amp), these are just some examples.
    Halfnutz
    Mar 2008
    161
    Thank you for the detailed explanation Craig.
    Since I'm only going to be running about 9 ft max of cable, it looks like I don't need an EMI filter on the output, and I don't really need to worry about what kind of EM I filter I use on the input so long as it is rated high enough.
    Mar 2008
    161
    Quote Originally Posted by Halfnutz View Post
    Thank you for the recommendation. I will look for some of these today.
    15362
    Thank you.
    How many Drive and what size are they
    Mactec54
    15362
    You would not be using a EMI Filter on the output, who ever suggested it, is talking Bs, if you where to use anything on the output it would be a 3% output line reactor, only for the input is a EMI Power Filter used and in some case's required, if you want to keep the return power clean, and your cabinet EMI noise low, ( 1 ) sized for all your drives would be all you need for the input power
    Mactec54
    15362
    They are RFI filters and are not suitable for EMI
    Mactec54
    15362
    You can get a quality EMI filter from any of the electrical suppliers, that is cheaper and the correct filter to use, what you list is RFI filters which is not suitable for EMI
    Mactec54
  1. Replies: 13
    Last Post: 09-24-2018, 05:17 PM
  2. Yaskawa servo motors and drives Controller help
    By bajlekov in forum Servo Motors / Drives
    Last Post: 05-15-2018, 07:15 PM
  3. Help with Yaskawa SGDM-04ADA-V ac servo drives
    By geebow in forum Servo Motors / Drives
    Last Post: 12-13-2015, 05:09 PM
  4. Replies: 0
    Last Post: 11-29-2015, 02:18 PM
  5. yaskawa SGDA-08AS SERVO DRIVES
    By blackbeard52 in forum Servo Drives
    Last Post: 07-08-2008, 02:07 PM
