586,069 active members*
3,403 visitors online*
Results 1 to 5 of 5
    Mar 2011
    230
    Alarms on my Leadwell MCV OP
    Hi guys
    Hope this is the correct place to put this??
    So I finally got my Leadwell powered up after 2 and half years sitting around (I think this is the main cause??) and got some errors.
    On first power up I had an EMG Alarm (Red LED) also flashing on screen said "not ready".
    So I read on this forum try pushing and holding "rest and Delete" during power up. (I probably shouldn't have done that)
    So now the alarm messages are,
    Spindle trouble (Other red LED)
    100 P/S Alarm
    417 servo alarm X axis DGTL Param etc. Ill post pics.
    I was told ill need to load Parameters back into the machine?????
    Attachment 471372
    Attachment 471374
    Mar 2011
    230
    Re: Alarms on my Leadwell MCV OP
    Just want to make sure this is the correct area to post this?
    Quote Originally Posted by toranacar View Post
    Hi guys
    100 P/S Alarm
    Attachment 471372
    Attachment 471374
    Are there any alarm codes on the servo drivers?
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Mar 2011
    230
    all i know are these alarms on the screen and red LED
    Aug 2019
    145
    "RESET+DELETE" clears all NC data. So you are correct in having to reload NC and PC parameters, as well as any Macro programs / variables that may have been used for machine.
    functions. You may also need to track down the option parameter settings if you don't already have them.
    Get that part sorted and see what you have left for alarms.
  1. Alarms on my Leadwell MCV OP
    By toranacar in forum Fanuc
    Last Post: 05-09-2022, 11:16 AM
  2. Leadwell MCV-0
    By dpaulson in forum Fanuc
    Last Post: 01-07-2016, 07:39 PM
  3. help with Leadwell MCV-OP
    By prec-tech in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2011, 06:34 AM
  4. MCV-OP Leadwell????
    By bdrmachine in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2006, 02:35 AM
