586,060 active members*
4,042 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Rigid Tapping G84, reversing feed out faster
Results 1 to 11 of 11
    Sep 2019
    30
    Hello guys,
    I have a milling machine with controller Fanuc 0i-F.
    I'm trying to make a thread but when is reversing out the feed is faster and speed is same and my thread is not good.
    My progrram:
    M00
    S100M3
    G0G90G54X0.0Y0.0M8
    G43Z50H4M8
    S100M29
    G84G98Z-42.0R2F150
    Y-15.
    Y-25.
    Y-35.
    G80
    The feed is 150 and for reversing is changing to 225.
    I want the feed to be same.
    Any help would be really appreciated.
    Nov 2007
    352
    Re: Rigid Tapping G84, reversing feed out faster
    Check the Parameters for the machine for Rigid Tapping --thats what is causing it
    Feb 2011
    353
    Another thing to check is the m code for rigid tapping
    m code a machine manufacturer dependent
    M29 is a standard but i have seen a fanuc controller using m53 instead
    Aug 2009
    1573
    ...a work around would be to write a Macro or subprogram or what ever to G91 the Z tap depth with 1st feedrate, than 1.5xfeedrate going up. Basically a custom bore cycle.
    Mar 2009
    1982
    Looks like you use feed rate per minute? Use feed per revolution. Maybe other "canned cycle" would work better.
    Dec 2012
    395
    I assume you use FANUC because you're in the FANUC forum and you use the Metric system.
    Within FANUC you can use G94 (mm/min) and G95 (mm/rev) for tapping, so two examples for a M10 x 1.5 tap:
    M00
    G94( MM/MIN = STANDARD )
    S300 M3
    G0 G90 G54 X0.0 Y0.0 M8
    G43 Z50 H4 M8
    S300 M29
    G84 G98 Z-42.0 R2. F450. ( F=SxP 300x1.5=450 )
    Y-15.
    Y-25.
    Y-35.
    G80
    M00
    S300 M3
    G43 Z50 H4 M8
    G95 ( MM/REV )
    S300 M29
    G84 G98 Z-42.0 R2. F1.5 ( F=PITCH )
    Y-15.
    Y-25.
    Y-35.
    G80
    G94 ( BACK TO MM/MIN )
    Aug 2019
    145
    A note on feed per rev. for rigid tapping. There is a note in the Fanuc manuals that states "Even in feed per revolution mode, pulses distributed for the drilling axis are converted to a command for feed per minute. Thus, feed per rotation mode does not strictly implement feed per rotation. Accordingly, even is the spindle stops for some reason, the drilling axis does not stop."
    A couple of items to check.
    Is this a new issue or is this the 1st time trying rigid tapping?
    If this is the 1st time trying rigid tapping. Are you sure the control is in rigid tap mode (confirmed using spindle monitor screen under system).
    Check parameter;
    5200.4 Override during extraction in rigid tapping.
    5200.5
    Hope this is of some help.
    Dec 2012
    395
    Hi oetkbyentc,
    Feed/Rev. or Feed/Min is synchronized with the spindle while tapping, you can check if you want, that's why Feed Hold doesn't work during tapping, only when it's move to an other X-Y location.
    Make a simple tap g-code and during tapping switch to Single Block --- change to Handle mode and use the MPG (handwheel) and turn it slowly in + or -.
    You can tap with the MPG if you want, the spindle is synchronized with the Feed per Rev. probably also with Feed/Min but I didn't try that one.
    It works on my FANUC (S---M29) and Mitsubishi G84 R--- Z--- F(pitch value) ,R (comma R for rigid tapping)
    You can try this for normal and rigid tapping with Feed/Min and Feed/Rev.
    p.s. Try this in a save and free space above your part !!!!
    Aug 2019
    145
    Not wanting to hy-jack this thread but,
    We understand that Feed Per Rev is synchronized with the spindle encoder unless sudo / coderless FPR is used. So if the spindle were to stop or slow down the axis should respond in kind. But Fanucs note indicates the axis keep moving. So I would agree with what Fanuc is saying that even if you program Rigid Tap in FPR the control converts it to FPM. I would also agree with Fanucs note in that if tapping was truly IPR the threads would be perfect even if the spindle parameters were wrong and the spindle was running at an incorrect speed as the axis feed would change to follow the programmed IPR based of of actual spindle speed. But if the actual spindle speed is off the threads are off which indicates Rigid tapping runs in IPM.
    Feed Hold has no bearing on the note I added. Many canned cycles / macro statements delay feed hold as you described.
    Sep 2019
    30
    Thank you for your help.
    I solved by changing parameter 5200 #4 DOV from 1 to 0 and now the feed is same for both directions.
    Aug 2009
    1573
    Quote Originally Posted by vanova20 View Post
    ...Tapmatic vs Ridge tapping..Fanuc was thinking flexable...sweet.
    Thank for the 5200 report
  1. PM25MV faster than 2500 RPM spindle but with rigid tapping?
    By hackish in forum Benchtop Machines
    Last Post: 12-26-2018, 06:13 PM
  2. Rigid tapping not authorised G84.1
    By August1898 in forum Cincinnati CNC
    Last Post: 07-09-2018, 08:02 PM
  3. Fanuc G84 rigid tapping code
    By Roadstercycle in forum Fanuc
    Last Post: 03-13-2018, 07:12 PM
  4. Replies: 1
    Last Post: 07-06-2014, 04:44 AM
  5. G84 Rigid tapping and more
    By Karl_T in forum CamSoft Products
    Last Post: 01-18-2012, 02:38 AM
