586,110 active members*
3,181 visitors online*
IndustryArena Forum > CAM Software > Mastercam > extracting and projecting simple curves
    Nov 2005
    244
    I had a solid part I was playing with last week. It seemed simple but 2 things made it a long process for me. I do not have the part to show.
    The part was a parasolid with open pockets that were at 5 different depths with inside radius that needed to be machined with a bullnose endmill.
    Is there a quick and easy way to flatten a solid face profile and or a solidpart?
    Thank You
    Nov 2005
    174
    If you are using MCX use XFORM Project, then select wireframe, you can define a Z high to project too. I always put that wireframe on another level to keep donw the clutter. If V9 or below just xform squash select wireframe.
  1. Trouble with projecting curves
    By rlrhett in forum MadCAM
    Last Post: 03-03-2007, 01:33 PM
  2. Extracting cycle times from FANUC OT
    By swilly in forum Fanuc
    Last Post: 12-30-2006, 11:19 PM
  3. Extracting cycle times from FANUC OT
    By swilly in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-13-2006, 02:17 PM
  4. Projecting lettering to a surface
    By wudbutcher in forum Mastercam
    Last Post: 12-03-2006, 08:11 PM
  5. Projecting Surfaces
    By infinti_bc in forum Rhino 3D
    Last Post: 04-13-2004, 06:26 PM
