586,067 active members*
5,239 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Newbie/initial setup; homing correct directions, wont travel past hard limits
    Oct 2021
    I have recently put together a cnc router. Using CNC sPRO v5 controller, and its online software or CNCjs software. I set it up (as per mfr instructions) with the limit switches set up so the back right corner is where it will go zero. Meaning any travel away from that corner is now negative on the classic x/y/z model.
    If i try to leave the corner I hit my 4mm travel limits. If I flip any axis, I run into the ends of everything. is this the classic way things are setup? Why can i not leave this corner to the other corner, which would be -1300,-1300?
    Dec 2013
    5717
    Re: Newbie/initial setup; homing correct directions, wont travel past hard limits
    Let me see if I understand. With the machine homed at the rear right corner the entire table is then in the lower left quadrant of the classic Cartesian coordinate diagram? And Z can only move negative (down) from the home position?
    That seems normal to me. I do much of my work in that quadrant because I like to zero on the upper right corner of the part. You only need to make sure that your part setup in CAM setup agrees with your machine.
    On the other hand, you should be able to set the work 0,0,0 anywhere on the table and work from there, it really has nothing to do with where the home position is.
    Maybe I'm not understanding the problem you are having.
    Jim Dawson
    Sandy, Oregon, USA
  1. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  2. Newbie Q regarding initial setup
    By czralv in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-12-2013, 03:10 AM
  3. Newbie questions on moving past initial setup
    By chris2112 in forum K2CNC
    Last Post: 02-15-2011, 08:22 AM
  4. Homing and Limits Setup
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2009, 04:12 AM
  5. New setup with Mach3 - Limits work, homing doesn't
    By journeyonline in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2007, 03:09 AM
