586,110 active members*
3,186 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > milling supper thin material.
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Dec 2013
    5717
    Re: milling supper thin material.
    Quote Originally Posted by longnho View Post
    I told them about that but they still asked me use material they supplied. so face it to the thickness of the part is only one choice
    I would not do the job, that is the craziest thing I ever heard.
    If you insist on doing the job, then glue the material to something flat and reasonably stiff that you can hold in your vice or clamp to your table. Then do the machine work, and then hand them the whole work piece and they can figure out how the release the glue without destroying the part. Oh and charge them a lot to do the work.
    Jim Dawson
    Sandy, Oregon, USA
  2. #22
    Jun 2015
    4154
    this reminds me of a custom practice : dead-term delivery, using their equipment / material, etc .... just do something, doesn't matter if you can't finish it, but be sure that you deliver it by monday 10 am, because their meeting is at 10:30, and they must present some results : boss, look, i tried, it didn't work, we will analyze why until our next meeting ?! yeah, tommy is a good guy, we have to suport it
  3. #23
    Jun 2010
    4256
    What you now need to do is to write out a quote, for 2 different ways of doing the job.
    #1: buy shim, machine: $N
    #2: their way, uncertain: $10N (or maybe $20N, with $10N deposit and NO guarantee of delivery and NO refund)
    Cheers
    Roger
  4. #24
    15362
    You sure they are not just messing with you.
    What grade is the Stainless Steel ???
    What kind of mill do you have ???
    Did you quote the job ???
    If you where to try and machine these parts, it could be done if you make a clamping frame around the part, and use a vacuum to hold it down, while you rough machine each part, leave stock ( .0008" ) for Grinding.
    There is another way as well to machine these parts, where you would feed the material under a clamping plate, to machine a small stick out from the clamp face, as you move the material through you would clamp over the machined area as well, you may still need the vacuum to help hold it down as well. just the clamping may work, but it will have to be a quality fixture for this to work.
    Mactec54
  5. #25
    Jun 2015
    4154
    that's kind of a gang mill
  6. #26
    15362
    Quote Originally Posted by deadlykitten View Post
    Nothing like it.
    Mactec54
  7. #27
    Jun 2015
    4154
    i mean like a gang lathe that feeds the material, only that is a mill
  8. #28
    15362
    No a Swiss type cnc lathe, multi tool / spindle, is really a very different process.
    Mactec54
  9. #29
    Apr 2018
    19
    thank you for your suggestions. I'm working on a Haas with vacuum plate. framing is an good idea to work on this job.
    regard.
  10. #30
    Apr 2018
    19
    lolz that's exactly what going on here.
  11. #31
    Apr 2018
    19
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    I will ask them for more $$ on this job. this is a prototype job so they are lazy to buy material
  12. #32
    Apr 2018
    19
Page 2 of 2 12
  1. thin plastic material for engraving
    By monkeyfist in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-16-2015, 09:39 PM
  2. Thin plastic engraving material
    By brian257 in forum Engraving Machines
    Last Post: 03-01-2013, 10:14 AM
  3. Best way to hold thin material for milling
    By toothandnail in forum MetalWork Discussion
    Last Post: 10-01-2012, 10:34 PM
  4. holding thin material on lathe
    By 40fordcoupe in forum MetalWork Discussion
    Last Post: 08-24-2011, 04:08 AM
  5. Any way to limit warping on thin material ???
    By flyinwilly in forum Waterjet General Topics
    Last Post: 03-11-2011, 05:02 PM
